I’ve got a WP7611 on a custom board running openwrt. Modemmanager detects AT&T SIM cards just fine, but with a Verizon SIM it will say broken/not found. Interestingly, the at+cpin? command will return +CPIN: READY.
This makes me think it may have to do with the firmware version on the modem; however, I have been unable to upgrade the modem because it seems the qmi-firmware-update program does not seem to support the sahara protocol. This thread discusses it some, but does not come to a conclusion that will work for me.
Since I could not update the firmware, I tried using the qmi-select-stored-image command to select the verizon modem and pri options that were already on the modem, but that did not solve the issue.
I can still issue AT commands and SSH into the modem, so I’m wondering if there is a possible path to upgrade the firmware through one of those options.
Unfortunately, when I tried to do this the first time, it seemed to get stuck on the step where it says installing & reboot ...
I left it going for about 3 hours, but I eventually rebooted my device. I then tried running the command again with the install argument (fwupdate install) to no avail. I also noticed that if I ssh in and run the reboot command, the shell stops responding, but hangs for several minutes before it appears to actually reboot.
Interestingly, I just tried again and it it gave me an error during the installing & reboot step and stopped responding over ssh.
root@swi-mdm9x28-wp:~# fwupdate download /tmp/WP76xx_Release16_VERIZON.spk
Connecting to service ...
Download started ...
Download successful
Installing & Reboot ...
Error during installation: LE_FAULT
I managed to follow the log output by running the fwupdate program in the background with &.
Here is the logread output.
Jan 6 00:03:58 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | partition.c partition_WriteSwifotaPartition() 1411 | Image type 23 len 65536
Jan 6 00:03:58 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c WriteData() 655 | Type 23 len 65536 wr 65536
Jan 6 00:03:58 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c WriteImageData() 1043 | chunk length: 65536
Jan 6 00:03:58 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c WriteImageData() 1054 | Image data write: CRC in header: 0x7d737bed, calculated CRC 0xb257185e
Jan 6 00:03:58 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c WriteImageData() 1071 | CurrentInImgOffset: 6488064CurrentImageSize: 6553600 wrLen: 65536
Jan 6 00:03:58 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c WriteImageData() 1054 | Image data write: CRC in header: 0x7d737bed, calculated CRC 0x7d737bed
Jan 6 00:03:58 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c WriteImageData() 1071 | CurrentInImgOffset: 6553600CurrentImageSize: 6553600 wrLen: 65536
Jan 6 00:03:58 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c WriteImageData() 1085 | Image data write end: CRC in header: 0x7d737bed, calculated CRC 0x7d737bed
Jan 6 00:03:58 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c pa_fwupdate_Download() 2261 | End of update: total read 69683259, full length expected 69683259
Download successful
Jan 6 00:04:06 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | partition.c partition_ComputeDataCrc32SwifotaPartition() 1366 | Offset 190 size 69682859 CRC 34fba230
Jan 6 00:04:06 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c pa_fwupdate_Download() 2305 | End of download: globalCrc 34fba230 length 69682859
Jan 6 00:04:06 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c pa_fwupdate_Download() 2306 | Expected CRC 34fba230
Jan 6 00:04:06 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c pa_fwupdate_Download() 2315 | Closing swifota partiton
Jan 6 00:04:06 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | partition.c partition_CloseSwifotaPartition() 1188 | Update for partiton swifota done with return 0
Jan 6 00:04:06 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c BuildMetaData() 2057 | Image length: 69683259
Jan 6 00:04:06 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c BuildMetaData() 2059 | Logical block: 2, Physical block: 2
Jan 6 00:04:07 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_fwupdate_singlesys.c WriteDwlStatus() 1742 | FW update download status stored.
Jan 6 00:04:07 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate T=main | pa_fwupdate_qmi.c pa_fwupdate_CloseSwifota() 2216 | Close SWIFOTA partition
Jan 6 00:04:07 swi-mdm9x28-wp user.info Legato: INFO | powerManagerService[1179]/powerMgr T=main | le_pm.c OnClientDisconnect() 298 | Client pid 1131 disconnected.
Jan 6 00:04:07 swi-mdm9x28-wp user.warn Legato: -WRN- | powerManagerService[1179]/powerMgr T=main | le_pm.c OnClientDisconnect() 315 | Releasing wakeup source 'legato_FWUpdate_fwupdateDaemon' on behalf of fwupdateDaemon/1131.
Jan 6 00:04:07 swi-mdm9x28-wp user.info Legato: INFO | powerManagerService[1179]/powerMgr T=main | le_pm.c OnClientDisconnect() 323 | Deleting wakeup source 'legato_FWUpdate_fwupdateDaemon' on behalf of pid 1131.
Jan 6 00:04:07 swi-mdm9x28-wp user.info Legato: INFO | powerManagerService[1179]/powerMgr T=main | le_pm.c OnClientConnect() 270 | Connection from client fwupdateDaemon/1131
Jan 6 00:04:07 swi-mdm9x28-wp user.warn Legato: -WRN- | fwupdateDaemon[1131]/framework T=main | fdMonitor.c le_fdMonitor_Create() 449 | FD Monitor object name 'fwupdateDaemon.fwupdateDaemon.le_pm' truncated to 'fwupdateDaemon.fwupdateDaemon.l'.
Jan 6 00:04:07 swi-mdm9x28-wp user.info Legato: INFO | powerManagerService[1179]/powerMgr T=main | le_pm.c le_pm_NewWakeupSource() 509 | Created new wakeup source 'legato_FWUpdate_fwupdateDaemon' for pid 1131.
Jan 6 00:04:07 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | partition.c partition_WriteMetaData() 2117 | MTD 6: Writing from CWE image 23
Jan 6 00:04:07 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | pa_flash_mtd.c pa_flash_GetInfo() 231 | MTD 6 "swifota": size 4f40000 (nbBlk 317), writeSize 1000, eraseSize 40000
Jan 6 00:04:07 swi-mdm9x28-wp user.info Legato: INFO | fwupdateDaemon[1131]/le_pa_fwupdate_singlesys T=main | partition.c partition_WriteMetaData() 2170 | MTD 6: Writing meta data to peb 0
Jan 6 00:04:10 swi-mdm9x28-wp user.err Legato: =ERR= | fwupdateDaemon[1131]/fwupdateDaemon T=main | fwupdateServer.c le_fwupdate_InstallAndMarkGood() 492 | !!! Error LE_FAULT
Jan 6 00:04:10 swi-mdm9x28-wp user.info Legato: INFO | powerManagerService[1179]/powerMgr T=main | le_pm.c OnClientDisconnect() 298 | Client pid 1131 disconnected.
Jan 6 00:04:10 swi-mdm9x28-wp user.warn Legato: -WRN- | powerManagerService[1179]/powerMgr T=main | le_pm.c OnClientDisconnect() 315 | Releasing wakeup source 'legato_FWUpdate_fwupdateDaemon' on behalf of fwupdateDaemon/1131.
Jan 6 00:04:10 swi-mdm9x28-wp user.info Legato: INFO | powerManagerService[1179]/powerMgr T=main | le_pm.c OnClientDisconnect() 323 | Deleting wakeup source 'legato_FWUpdate_fwupdateDaemon' on behalf of pid 1131.
Jan 6 00:04:10 swi-mdm9x28-wp user.info Legato: INFO | supervisor[1031]/supervisor T=main | proc.c proc_SigChildHandler() 2079 | Process 'fwupdate@0' (PID: 2383) has exited with exit code 1.
Jan 6 00:04:12 swi-mdm9x28-wp user.warn Legato: -WRN- | supervisor[1031]/supervisor T=main | app.c app_SigChildHandler() 4066 | Process 'fwupdate@0' in app 'tools' faulted: Ignored.
Jan 6 00:04:12 swi-mdm9x28-wp user.info Legato: INFO | supervisor[1031]/supervisor T=main | app.c app_StopComplete() 4753 | app 'tools' has stopped.
Jan 6 00:04:12 swi-mdm9x28-wp user.info Legato: INFO | supervisor[1031]/supervisor T=main | apps.c DeactivateAppContainer() 374 | Application 'tools' has stopped.
I’m sorry, I’m not sure I understand.
Do you mean install onto the WP7611? I think legato is already installed on the modem. There is a legato folder in the base directory; however, if i run the app list command I do not see legato in the output.(I apologize, I don’t know a ton about this system)
As for my host board, maybe i could cross compile something.
Also it looks like a new release dropped yesterday. I’ll try looking at some of that documentation for help.
As for installing the new legato image, I downloaded the file for “base legato system” and it came as a .tar.bz2. I passing it into the fwupdate and it did not work.
I’ve tried doing fwupdate download with both linux-SWI9X07Y_02.37.10.02.cwe and WP76xx_Release16.0.1_VERIZON.spk. That is how I got the result in my previous message.
