Hello jyijyi,
thank you for your reply
Here are the answers to the Hayes questions asked :
AT!ENTERCND=“A710”
AT!IMPREF?
!IMPREF:
preferred fw version: 00.08.07.00
preferred carrier name: SIERRA
preferred config name: SIERRA_000.057_000
preferred subpri index: 001
current fw version: 00.08.07.00
current carrier name: SIERRA
current config name: SIERRA_000.057_000
current subpri index: 001
AT!GSTATUS?
!GSTATUS:
Current Time: 140 Temperature: 36
Reset Counter: 1 Mode: ONLINE
System mode: WCDMA PS state: Attached
IMS reg state: NOT REGISTERED IMS mode: Normal
IMS Srv State: NO SMS,NO VoIP
WCDMA band: WCDMA 900
WCDMA channel: 3075
GMM (PS) state:REGISTERED NORMAL SERVICE
MM (CS) state: IDLE NORMAL SERVICE
WCDMA L1 state:L1M_PCH_SLEEP LAC: C296 (49814)
RRC state: DISCONNECTED UTRAN Cell ID: 01526FF7 (22179831)
RxM RSSI C0: — RxD RSSI C0: —
RxM RSSI C1: — RxD RSSI C1: —
AT+CEREG?
+CEREG: 0,5
AT+CGDCONT?
+CGDCONT: 1,“IP”,“m2mroaming17”,“0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“sos”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,1
AT+CFUN?
+CFUN: 1
Here is the log of the connection attempt
I have hidden the identifiers
REDY: Loading profile at /var/etc/qmi/qmi-network.conf…
REDY: APN: m2mroaming17
REDY: APN user: ------------
REDY: APN password: -------------
REDY: APN auth: CHAP
REDY: qmi-proxy: no
REDY: Checking data format with ‘qmicli -d /dev/cdc-wdm0 --wda-get-data-format ‘…
REDY: Device link layer protocol retrieved: raw-ip
REDY: Getting expected data format with ‘qmicli -d /dev/cdc-wdm0 --get-expected-data-format’…
REDY: Expected link layer protocol retrieved: 802-3
REDY: Updating kernel link layer protocol with ‘qmicli -d /dev/cdc-wdm0 --set-expected-data-format=raw-ip’…
REDY: Kernel link layer protocol updated
REDY: Starting network with ‘qmicli -d /dev/cdc-wdm0 --wds-start-network=apn=‘m2mroaming17’,username=’-----------’,password=’-------------’,auth=‘CHAP’ --client-no-release-cid '…
REDY: error: couldn’t start network: QMI protocol error (14): ‘CallFailed’
REDY: call end reason (1): generic-unspecified
REDY: verbose call end reason (2,209): [internal] pdn-ipv4-call-throttled
REDY: Saving state at /var/etc/qmi/qmi-network-state-cdc-wdm0… (CID: 3)
REDY: error: network start failed, no packet data handle
REDY: Clearing state at /var/etc/qmi/qmi-network-state-cdc-wdm0…
Thank you for your help
See you soon
JFT
