How about just dmesg to find out the port
dmesg.txt (80.6 KB)
i think i could find it, attached the output
then it seems your linux or the usb port of linux has problem
if ping works that mean Linux can recognize the CF3 module via the USB port, right? Then is able to know which USB port it is pinging? It is not the problem with my PC, right?
There are two USB ports, one is the USB interface of the module, another one is the UART console.
You are connecting the USB interface, that is why you can ping the PC.
Can i use the Developer studio then to create apps for WP7702 module?
Yes, but for old fw only
is it a common problem regarding USB and Linux via VMWare? what would be the solution?
it should be something like this, the driver should be generic one:
The guy changed the mangOH, after that it works. For my case, this is a new yellow mangOH brought it from digikey.
The hardware should be fine as you can see it in device manager
Why don’t you use windows to control the uart console?
you might see these links:
how about Cntl + Shift + P and choose create new system (Legato/System:New)
can you help to have simple apps to print “hello world”. Sorry I am not good with coding. Just need to test whether the whole system works or not.
