Loading Open AT IDE…
bash.exe: warning: could not find /tmp, please create!
Done.
Loading project settings…
done.
Building gcc_test_H project…
Launch a full library or binary process
Cleaning object files (.o)
Cleaning binary files (.bin / .axf / .elf / .wpb / s, m)
Remove TMT resources in …/out/tmt
Cleaning status files report (.log)
Cleaning errors files (*.lst / *.err / *.gpp)
Cleaning temporary files (*.tmp / *.trc)
Deleting local sources files (.c/.cpp)
Deleting local assembler files (.asm)
Deleting local header files (.h*, .i)
Deleting mmi scenarii if exist (.sce)
Deleting all csn1 description files if exist (*.csn, *.cso)
Cleaning sources list file (…/out/gcc_test_H.src)
(…/out/gcc_test_H_csn.src)
Cleaning filtering file (…/out/gcc_test_H.flt)
Cleaning dependencies file (…/out/gcc_test_H.dep)
(…/out/gcc_test_H_asm.dep
(…/out/gcc_test_H_sce.dep)
(…/out/gcc_test_H_csn.dep)
… Dependency graph is being built …
… Build sources filtering rules for gcc_test_H
Get …/…/src/hello_world.c hello_world.c
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_global.h adl_global.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/basic/wm_types.h wm_types.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/basic/wm_stdio.h wm_stdio.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/basic/wm_remote.h wm_remote.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/basic/wm_list.h wm_list.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/basic/wm_snd.h wm_snd.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_str.h adl_str.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_port.h adl_port.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_at.h adl_at.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_traces.h adl_traces.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_memory.h adl_memory.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_error.h adl_error.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_flash.h adl_flash.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_gpio.h adl_gpio.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_bus.h adl_bus.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_fcm.h adl_fcm.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_osa.h adl_osa.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_AppliInit.h adl_AppliInit.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_UnSoHandler.h adl_UnSoHandler.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_RspHandler.h adl_RspHandler.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_CmdHandler.h adl_CmdHandler.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_CmdStackHandler.h adl_CmdStackHandler.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_TimerHandler.h adl_TimerHandler.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_sim.h adl_sim.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_sms.h adl_sms.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_call.h adl_call.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_gprs.h adl_gprs.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_safe.h adl_safe.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_ad.h adl_ad.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_rtc.h adl_rtc.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_ctx.h adl_ctx.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_msg.h adl_msg.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_irq.h adl_irq.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_sctu.h adl_sctu.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_vs.h adl_vs.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_sem.h adl_sem.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_extint.h adl_extint.h
Use YTPP
Get C:/OpenAT/OS/4.10.10/ADL/itf/adl_dac.h adl_dac.h
Use YTPP
… Compiling hello_world.c
Copy all needed library and object files
Make links C:/OpenAT/OS/4.10.10/ADL/gcc_wmadl_4.10.5.2.0.lib …/out/gcc_wmadl_4.10.5.2.0.lib
… Link step in progress …
… Link gcc_test_H.bin …
Extract gcc_test_H.bin from gcc_test_H.axf (or from gcc_test_H.elf if Gcc ARM compiler is used)
Update symbol file -> ../out/s
Compress gcc_test_H.bin to gcc_test_H.wpb for DWLWIN application
… Make TMT directory …
Make links …/out/s …/out/tmt/symbolfiles/s
Create …/out/tmt/config/DiagnoseTips.ini
Create …/out/tmt/config/MokaWatches.ini
Create …/out/tmt/config/RemoteDefs.ini
Create …/out/tmt/gcc.wks
No remote trace file found
Create TMT archive file
ls: …/out/pro-lib.bin: No such file or directory
Make an archive file for TMT application
zip warning: name not matched: ../out/tmt/e2p_csn.cso
zip error: Nothing to do! (…/out/tmt/zip_tmt.zip)
zip warning: name not matched: …/out/tmt/backtraces.axf
zip warning: name not matched: …/out/tmt/backtraces64k.axf
zip warning: name not matched: …/out/tmt/symbolfiles/s64k
zip warning: name not matched: …/out/tmt/symbolfiles/e2p.h
adding: s (176 bytes security) (deflated 68%)
enter new zip file comment (end with .):
current zip file comment is:
[Binary Information]
Stack Version = Open-AT
Customer Version = gcc
Binary Name = pro-lib.bin
Size =
Date = Wed Feb 28 2007
Time = 00:00:00
Size =
Time = 00:00:00
adding: DiagnoseTips.ini (176 bytes security) (deflated 87%)
Size =
Time = 00:00:00
adding: MokaWatches.ini (176 bytes security) (deflated 67%)
Size =
Time = 00:00:00
adding: RemoteDefs.ini (176 bytes security) (deflated 74%)
Size =
Time = 00:00:00
Rename …/out/tmt/zip_tmt.zip …/out/tmt/gcc.zip
Keep only the TMT archive file in …/out/tmt
Remove …/out/tmt/e2p_csn.cso
Remove …/out/tmt/sys_ftr.ho
Remove …/out/tmt/wm_ftr.ho
Remove …/out/tmt/remtrace.csv
Remove …/out/tmt/backtraces.axf
Remove …/out/tmt/backtraces64k.axf
Remove …/out/tmt/remtrace_full.csv
Remove …/out/tmt/symbolfiles directory
Remove …/out/tmt/config directory
… Create binary in X-MODEM format from gcc_test_H.bin …
Add a checksum to gcc_test_H.sgt
(AddCheck Version v2.0.4 Copyright (c) WAVECOM) [Feb 14 2003, 15:50:57]
Time modified : Wed Feb 28 10:50:06 2007
… Build gcc_test_H.dwl …
genBin : Version v1a06 Copyright (c) WAVECOM
genBin : No Error
Generation done with SGT v1.2.12oat
Binary files created :
gcc_test_H.bin
pro-dwl.bin
Binary files in Xmodem format :
gcc_test_H.dwl
Compiler keyword : gcc_arm
Compiler release : GCC ARM
C compiler path : C:/OpenAT/IDE/GCC/4.0.1.0/bin/arm-elf-gcc
ASM compiler path : C:/OpenAT/IDE/GCC/4.0.1.0/bin/arm-elf-gcc
customer release : gcc
Name of the current directory : gcc
Log file : …/out/gcc_test_H_status.log
Release of the environement : CYGWIN_NT-5.0 WS01 1.5.10(0.116/4/2) 2004-05-25 22:07 i686 unknown unknown Cygwin
Build an X-MODEM binary : 'gcc_test_H.wpb.dwl'
… Convert gcc_test_H.wpb in X-MODEM format …
genBin : No Error
… Build gcc_test_H.wpb.dwl …
AXFshrinker Version 1.0.0.1 ( Aug 23 2002 , 17:44:58 )
adding: backtraces.axf (deflated 74%)
Done.
