I am using the Fastrack Supreme with the GPS add on card and an active GPS antenna. After running the Query sample I see that there is no fix on the GPS even after several hours. When I connect to my PDA the same antenna at the same location (outdoor with clear view to the sky) I get a lock at 8 to 10 satellites and a position fix in a couple of minutes. Should I enable something first? Maybe turn on the power to the antenna?
