Multiple FX30s connected to Windows?
Hi, is there a way to have multiple FX30s connected to Windows at the same time? I cannot get this to work… there seems to be a conflict in the drivers as it is not able to enumerate both devices at the same time?
Karl
Hi Karl,
If you connect using usb you’ll have to log on to the FX30 first and use ecmConfig to change the usb ip address.
If you’re using ethernet you’ll need to change the static ip assigned to the eth0 port.
BR,
Chris
Ok thanks for the info @cchenry . I will give that a go.
PS It is configEcm and not ecmConfig for anyone trying to sort this out.
