MP70 unreachable via SNMP. SNMP service is on and server is in the allow list with proper credentials
We have about 40 of these and all work except one. Concerned that this may be a hardware issue. I enabled SNMPv3 but a port scan shows 161 closed and the server shows it as unreachable over SNMP (ping and login is fine).
Hi @dflick,
Welcome to our community!
Among the devices that are working well, do any of them have the same ALEOS version and radio firmware as the one facing the issue?
Is the MP70 that’s experiencing the issue configured the same way as the working MP70?
Please use the template from the MP70 that’s working fine with the same firmware for the MP70 facing the issue to see if it resolves the issue.
Yes the versions are the same and we build these using templates so they are identical except for IP addresses. We have reconfigured and rebooted several times
Hi @dflick,
Is the template file for the MP70 experiencing issues still available? Please share both the template for the working MP70 and the one with issues.
You can try resetting the problematic MP70 device to factory settings and then applying the template from the functional MP70 with the same firmware to see if it resolves the problem.
Working config:
<?xml version="1.0" ?>
Non-working config
I am unable to upload files so I had to do it inline.
These templates are auto-generated from automation so they are identical with the exception of IP address.
I can’t find any log to show that the modem sees the packet or that the snmp service is working. Here are dubug logs captured today. We tested about 6 times
Oct 18 16:56:48 warning ALEOS_EVENTS_dpRptGen: No GNSS Fix. Quality Indicator is 0 and 0 Satellites in Use. 2939766 seconds passed without fix.
Oct 18 17:02:17 notice ALEOS_SERVICES_SNTP: Current time: Wed, 18 Oct 2023 17:02:17 UTC SNTP time used to set both system time and HW clock system time to: Wed, 18 Oct 2023 17:02:17 UTC
Oct 18 17:04:31 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-48, RSRQ=-16, RSRP=-78, SINR=12.1
Oct 18 17:06:33 notice ALEOS_SERVICES_McuManager: ProcessPolling McuManager handled [19600] poll
Oct 18 17:13:52 warning ALEOS_EVENTS_dpRptGen: No GNSS Fix. Quality Indicator is 0 and 0 Satellites in Use. 2940789 seconds passed without fix.
Oct 18 17:19:31 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-49, RSRQ=-11, RSRP=-78, SINR=14
Oct 18 17:30:56 warning ALEOS_EVENTS_dpRptGen: No GNSS Fix. Quality Indicator is 0 and 0 Satellites in Use. 2941814 seconds passed without fix.
Oct 18 17:34:31 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-50, RSRQ=-16, RSRP=-78, SINR=12.7
Oct 18 17:48:00 warning ALEOS_EVENTS_dpRptGen: No GNSS Fix. Quality Indicator is 0 and 0 Satellites in Use. 2942837 seconds passed without fix.
Oct 18 17:49:31 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-46, RSRQ=-15, RSRP=-78, SINR=7.7
Oct 18 18:04:31 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-47, RSRQ=-15, RSRP=-78, SINR=14.5
Oct 18 18:05:04 warning ALEOS_EVENTS_dpRptGen: No GNSS Fix. Quality Indicator is 0 and 0 Satellites in Use. 2943862 seconds passed without fix.
Oct 18 18:08:19 notice ALEOS_SERVICES_SNTP: Current time: Wed, 18 Oct 2023 18:08:18 UTC SNTP time used to set both system time and HW clock system time to: Wed, 18 Oct 2023 18:08:19 UTC
Oct 18 18:19:31 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-44, RSRQ=-19, RSRP=-78, SINR=10.6
Oct 18 18:22:08 warning ALEOS_EVENTS_dpRptGen: No GNSS Fix. Quality Indicator is 0 and 0 Satellites in Use. 2944885 seconds passed without fix.
Oct 18 18:34:31 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-51, RSRQ=-11, RSRP=-78, SINR=11.6
Oct 18 18:39:12 warning ALEOS_EVENTS_dpRptGen: No GNSS Fix. Quality Indicator is 0 and 0 Satellites in Use. 2945910 seconds passed without fix.
Oct 18 18:43:45 notice ALEOS_WEB_ACEmanager: User [user] login successful from IP [10.117.212.90]
Oct 18 18:48:20 alert ALEOS_SYSTEM_[logconfig]: ALEOS_SERVICES log level → ALEOS_DEBUG
Oct 18 18:48:29 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Oct 18 18:48:29 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:48:29 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:48:29 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:48:29 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:48:59 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 0
Oct 18 18:48:59 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:49:04 debug ALEOS_SERVICES_McuManager: ProcessTimers - Poll MCU data required for other applications
Oct 18 18:49:04 info ALEOS_SERVICES_McuManager: ProcessPolling
Oct 18 18:49:04 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_VIN] was read and returned translated value [1210] - rawMcuReading = [0x0004f9]
Oct 18 18:49:04 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO1_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:49:04 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO2_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:49:04 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO3_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:49:04 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_TEMP] was read and returned translated value [33] - rawMcuReading = [0x00095d]
Oct 18 18:49:04 debug ALEOS_SERVICES_McuManager: 13CayenneMcuHal readOp: MCU System State at: /sys/devices/system/mcusw/mcusw_cmd/mcu_sys_state- mcu system state: 0x552c5104
Oct 18 18:49:04 debug ALEOS_SERVICES_McuManager: 13CayenneMcuHal mcu_ignition_sense: ADC Ignition Digital level [1]
Oct 18 18:49:19 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:49:19 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:49:19 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:49:19 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:49:19 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Oct 18 18:49:31 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-51, RSRQ=-16, RSRP=-78, SINR=10.9
Oct 18 18:49:49 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 0
Oct 18 18:49:49 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:49:54 alert ALEOS_SYSTEM_[logconfig]: ALEOS_SECURITY log level → ALEOS_DEBUG
Oct 18 18:49:54 alert ALEOS_SYSTEM_[logconfig]: ALEOS_APPS log level → ALEOS_DEBUG
Oct 18 18:49:54 alert ALEOS_SYSTEM_[logconfig]: ALEOS_SYSTEM log level → ALEOS_DEBUG
Oct 18 18:49:54 alert ALEOS_SYSTEM_[logconfig]: ALEOS_NETSERV log level → ALEOS_DEBUG
Oct 18 18:49:54 alert ALEOS_SYSTEM_[logconfig]: ALEOS_CONNECTMGMT log level → ALEOS_DEBUG
Oct 18 18:49:54 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17004) = “7”
Oct 18 18:49:54 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17008) = “7”
Oct 18 18:49:54 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17012) = “7”
Oct 18 18:49:54 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17013) = “7”
Oct 18 18:49:54 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17017) = “7”
Oct 18 18:49:54 debug ALEOS_SYSTEM_CSM: added 55562 - 1697654994. to smio as rcdlen 18
Oct 18 18:49:54 debug ALEOS_SYSTEM_CSM: sent smio msg ret = 0
Oct 18 18:49:54 debug ALEOS_SYSTEM_CSM: DATA_RSP
Oct 18 18:50:09 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Oct 18 18:50:09 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:50:09 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:50:09 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:50:09 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:50:25 debug ALEOS_SYSTEM_STS: get_connected_host - Command to obtain ARP cache: ip neighbour show to 0.0.0.0/0 | grep -E ‘br0|usb0’
Oct 18 18:50:25 debug ALEOS_SYSTEM_STS: get_connected_host: There are 1 ethernet entries in the arp table
Oct 18 18:50:31 debug ALEOS_SYSTEM_Cmdexe: The incoming carrier aggregation base class to find Active Secondary Frequency Band is: 121
Oct 18 18:50:39 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 0
Oct 18 18:50:39 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:50:59 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Oct 18 18:50:59 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:50:59 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:50:59 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:50:59 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:51:08 debug ALEOS_SYSTEM_CSM: added 10283 - 50765073. to smio as rcdlen 16
Oct 18 18:51:08 debug ALEOS_SYSTEM_CSM: sent smio msg ret = 0
Oct 18 18:51:08 debug ALEOS_SYSTEM_CSM: DATA_RSP
Oct 18 18:51:10 debug ALEOS_SYSTEM_CSM: added 17002 - 7. to smio as rcdlen 9
Oct 18 18:51:10 debug ALEOS_SYSTEM_CSM: added 17006 - 7. to smio as rcdlen 9
Oct 18 18:51:10 debug ALEOS_SYSTEM_CSM: added 17011 - 7. to smio as rcdlen 9
Oct 18 18:51:10 debug ALEOS_SYSTEM_CSM: sent smio msg ret = 0
Oct 18 18:51:10 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17002) = “7”
Oct 18 18:51:10 alert ALEOS_SYSTEM_[logconfig]: ALEOS_LAN log level → ALEOS_DEBUG
Oct 18 18:51:10 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17006) = “7”
Oct 18 18:51:10 alert ALEOS_SYSTEM_[logconfig]: ALEOS_EVENTS log level → ALEOS_DEBUG
Oct 18 18:51:10 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17011) = “7”
Oct 18 18:51:10 alert ALEOS_SYSTEM_[logconfig]: ALEOS_ADMIN log level → ALEOS_DEBUG
Oct 18 18:51:10 debug ALEOS_SYSTEM_CSM: added 55562 - 1697655070. to smio as rcdlen 18
Oct 18 18:51:10 debug ALEOS_SYSTEM_CSM: DATA_RSP
Oct 18 18:51:29 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 0
Oct 18 18:51:29 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:51:34 debug ALEOS_SERVICES_McuManager: ProcessTimers - Poll MCU data required for other applications
Oct 18 18:51:34 info ALEOS_SERVICES_McuManager: ProcessPolling
Oct 18 18:51:34 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_VIN] was read and returned translated value [1210] - rawMcuReading = [0x0004f9]
Oct 18 18:51:34 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO1_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:51:34 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO2_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:51:34 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO3_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:51:34 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_TEMP] was read and returned translated value [33] - rawMcuReading = [0x00095d]
Oct 18 18:51:34 debug ALEOS_SERVICES_McuManager: 13CayenneMcuHal readOp: MCU System State at: /sys/devices/system/mcusw/mcusw_cmd/mcu_sys_state- mcu system state: 0x552c5104
Oct 18 18:51:34 debug ALEOS_SERVICES_McuManager: 13CayenneMcuHal mcu_ignition_sense: ADC Ignition Digital level [1]
Oct 18 18:51:44 debug ALEOS_SYSTEM_STS: get_connected_host - Command to obtain ARP cache: ip neighbour show to 0.0.0.0/0 | grep -E ‘br0|usb0’
Oct 18 18:51:44 debug ALEOS_SYSTEM_STS: get_connected_host: There are 1 ethernet entries in the arp table
Oct 18 18:51:49 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Oct 18 18:51:49 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:51:49 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:51:49 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:51:49 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:52:19 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 0
Oct 18 18:52:19 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:52:20 debug ALEOS_SERVICES_SNTP: 10CayenneHal get_xcard_id: XCARD BITMASK = 0x0000
Oct 18 18:52:20 debug ALEOS_SERVICES_SNTP: 13CayenneMcuHal read_time: Channel /sys/devices/system/mcusw/mcusw_cmd/mcu_utc_readback: value: << result: 0x65302963 | error: 0x0 >>
Oct 18 18:52:20 info ALEOS_SERVICES_SNTP: 10CayenneHal get_aleos_time: Valid MCU UTC time at << /sys/devices/system/mcusw/mcusw_cmd/mcu_utc_readback >>.
Oct 18 18:52:20 info ALEOS_SERVICES_SNTP: 10CayenneHal set_aleos_time: HW Clock is set to System Time
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: UpdateConfigState() entered, current state STATE_COMPLETED event EVENT_DATA_CHANGED
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: UpdateConfigState() changing state from STATE_COMPLETED to STATE_INCOMPLETE
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() msciId TIME UPDATE CNT type 1 value 32305
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: UpdateValue() MSCIID TIME UPDATE CNT updated to 32305
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: UpdateConfigState() entered, current state STATE_INCOMPLETE event EVENT_END_MSG
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: CheckToDSettings() Time of Day settings validated
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: UpdateConfigState() settings verified, changing state from STATE_INCOMPLETE to STATE_READY
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: SetConfigBitmask() time set at start and can be sent
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: SetConfigBitmask() UTC time has changed
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: SetConfigBitmask() config mask 0xbf
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: WriteSettings() CSM bit mask 0xbf MCU bit mask 0x0
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: start_lpm_configuration() start writing MCU configuration
Oct 18 18:52:20 debug ALEOS_SERVICES_SNTP: 13CayenneMcuHal read_time: Channel /sys/devices/system/mcusw/mcusw_cmd/mcu_utc_readback: value: << result: 0x65302964 | error: 0x0 >>
Oct 18 18:52:20 debug ALEOS_SERVICES_SNTP: Current time: Wed, 18 Oct 2023 18:52:19 UTC SNTP time used to set both system time and HW clock system time to: Wed, 18 Oct 2023 18:52:20 UTC
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: WriteTodSettings() minsSinceMidnight 1132 minsInCycle 52 minsLeft 18 secsLeft 1060 isActive 0
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: WriteTodSettings() isEnabled 0 minsOn 40 minsOff 20secsLeft 1060 isActive 0
Oct 18 18:52:20 debug ALEOS_SERVICES_SNTP: SNTP: all ALEOS time components successfully synced.
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: write_lpm_time_of_day() LPM Time of Day feature is [disabled]
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: write_lpm_time_of_day() LPM Time of Day settings 3.0.40.20.1060.0
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: start_lpm_configuration() end writing MCU configuration
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: LpmMgrSetupTimers() called, setting timer delay to 3000 mSecs
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: UpdateConfigState() entered, current state STATE_READY event EVENT_TX_CONFIG
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: UpdateConfigState() changing state from STATE_READY to STATE_COMPLETED
Oct 18 18:52:20 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:52:23 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 0
Oct 18 18:52:23 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:52:23 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers - Begin MCU status checking
Oct 18 18:52:23 debug ALEOS_SERVICES_lpmmgr: 13CayenneMcuHal readOp: MCU System State at: /sys/devices/system/mcusw/mcusw_cmd/mcu_sys_state- mcu system state: 0x552c5104
Oct 18 18:52:23 debug ALEOS_SERVICES_lpmmgr: 13CayenneMcuHal lpm_config_status: LPM configuration Status: 0.
Oct 18 18:52:23 debug ALEOS_SERVICES_lpmmgr: LpmMgrAreChecksumsSame() MCU LPM Config Check Sum: 0x552c
Oct 18 18:52:23 debug ALEOS_SERVICES_lpmmgr: LpmMgrAreChecksumsSame() all settings checksum 0x552c
Oct 18 18:52:23 debug ALEOS_SERVICES_lpmmgr: LpmMgrAreChecksumsSame() Ignition and LVD checksum 0x552c
Oct 18 18:52:23 debug ALEOS_SERVICES_lpmmgr: LpmMgrAreChecksumsSame() All settings checksum matches.
Oct 18 18:52:39 debug ALEOS_SECURITY_GAR: Type of event: SYSCALL(1300)
Oct 18 18:52:39 debug ALEOS_SECURITY_GAR: Record type: 1300(SYSCALL) has 28 fields
Oct 18 18:52:39 debug ALEOS_SECURITY_GAR: Event time: Wed, 18 Oct 2023 18:42:39 UTC
Oct 18 18:52:39 debug ALEOS_SECURITY_GAR: The Key for the event received: USR_DIR
Oct 18 18:52:39 debug ALEOS_SECURITY_GAR: ConstructLogMsg: number of records: 4 that will be iterated through
Oct 18 18:52:39 debug ALEOS_SECURITY_GAR: ConstructLogMsg: touch /usr/local/sbin/auditEventFlush, touch, /bin/busybox, /, EROFS(Read-only file system), openat, 4.16.2.001
Oct 18 18:52:39 debug ALEOS_SECURITY_GAR: Type of event: CWD(1307)
Oct 18 18:52:39 debug ALEOS_SECURITY_GAR: Type of event: PATH(1302)
Oct 18 18:52:39 debug ALEOS_SECURITY_GAR: Type of event: PROCTITLE(1327)
Oct 18 18:52:39 debug ALEOS_SECURITY_GAR: Type of event: EOE(1320)
Oct 18 18:52:39 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Oct 18 18:52:39 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:52:39 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:52:39 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:52:39 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:53:04 debug ALEOS_SYSTEM_STS: get_connected_host - Command to obtain ARP cache: ip neighbour show to 0.0.0.0/0 | grep -E ‘br0|usb0’
Oct 18 18:53:04 debug ALEOS_SYSTEM_STS: get_connected_host: There are 1 ethernet entries in the arp table
Oct 18 18:53:09 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 0
Oct 18 18:53:09 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:53:18 debug ALEOS_SYSTEM_CSM: added 17000 - 1. to smio as rcdlen 9
Oct 18 18:53:18 debug ALEOS_SYSTEM_CSM: added 17100 - 1. to smio as rcdlen 9
Oct 18 18:53:18 debug ALEOS_SYSTEM_CSM: sent smio msg ret = 0
Oct 18 18:53:18 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17000) = “1”
Oct 18 18:53:18 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17100) = “1”
Oct 18 18:53:18 debug ALEOS_SYSTEM_CSM: added 55562 - 1697655198. to smio as rcdlen 18
Oct 18 18:53:18 debug ALEOS_SYSTEM_CSM: DATA_RSP
Oct 18 18:53:30 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:53:30 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:53:30 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:53:30 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:53:30 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Oct 18 18:54:00 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 0
Oct 18 18:54:00 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:54:04 debug ALEOS_SERVICES_McuManager: ProcessTimers - Poll MCU data required for other applications
Oct 18 18:54:04 info ALEOS_SERVICES_McuManager: ProcessPolling
Oct 18 18:54:04 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_VIN] was read and returned translated value [1210] - rawMcuReading = [0x0004f9]
Oct 18 18:54:04 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO1_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:54:04 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO2_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:54:04 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO3_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:54:04 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_TEMP] was read and returned translated value [33] - rawMcuReading = [0x00095d]
Oct 18 18:54:04 debug ALEOS_SERVICES_McuManager: 13CayenneMcuHal readOp: MCU System State at: /sys/devices/system/mcusw/mcusw_cmd/mcu_sys_state- mcu system state: 0x552c5104
Oct 18 18:54:04 debug ALEOS_SERVICES_McuManager: 13CayenneMcuHal mcu_ignition_sense: ADC Ignition Digital level [1]
Oct 18 18:54:20 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Oct 18 18:54:20 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:54:20 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:54:20 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:54:20 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:54:23 debug ALEOS_SYSTEM_STS: get_connected_host - Command to obtain ARP cache: ip neighbour show to 0.0.0.0/0 | grep -E ‘br0|usb0’
Oct 18 18:54:24 debug ALEOS_SYSTEM_STS: get_connected_host: There are 1 ethernet entries in the arp table
Oct 18 18:54:34 debug ALEOS_SYSTEM_CSM: added 10283 - 50765149. to smio as rcdlen 16
Oct 18 18:54:34 debug ALEOS_SYSTEM_CSM: sent smio msg ret = 0
Oct 18 18:54:34 debug ALEOS_SYSTEM_CSM: DATA_RSP
Oct 18 18:54:50 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 0
Oct 18 18:54:50 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:55:10 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Oct 18 18:55:10 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:55:10 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:55:10 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:55:10 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:55:40 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 0
Oct 18 18:55:40 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:55:43 debug ALEOS_SYSTEM_STS: get_connected_host - Command to obtain ARP cache: ip neighbour show to 0.0.0.0/0 | grep -E ‘br0|usb0’
Oct 18 18:55:43 debug ALEOS_SYSTEM_STS: get_connected_host: There are 1 ethernet entries in the arp table
Oct 18 18:56:00 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Oct 18 18:56:00 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:56:00 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:56:00 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:56:00 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:56:16 warning ALEOS_EVENTS_dpRptGen: No GNSS Fix. Quality Indicator is 0 and 0 Satellites in Use. 2946933 seconds passed without fix.
Oct 18 18:56:30 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 0
Oct 18 18:56:30 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:56:34 debug ALEOS_SERVICES_McuManager: ProcessTimers - Poll MCU data required for other applications
Oct 18 18:56:34 info ALEOS_SERVICES_McuManager: ProcessPolling
Oct 18 18:56:34 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_VIN] was read and returned translated value [1210] - rawMcuReading = [0x0004f9]
Oct 18 18:56:34 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO1_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:56:34 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO2_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:56:34 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_IO3_ANALOG] was read and returned translated value [1] - rawMcuReading = [0x000001]
Oct 18 18:56:34 debug ALEOS_SERVICES_McuManager: ADC channel [ADC_LOGICAL_TEMP] was read and returned translated value [33] - rawMcuReading = [0x00095f]
Oct 18 18:56:34 debug ALEOS_SERVICES_McuManager: 13CayenneMcuHal readOp: MCU System State at: /sys/devices/system/mcusw/mcusw_cmd/mcu_sys_state- mcu system state: 0x552c5104
Oct 18 18:56:34 debug ALEOS_SERVICES_McuManager: 13CayenneMcuHal mcu_ignition_sense: ADC Ignition Digital level [1]
Oct 18 18:56:50 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Oct 18 18:56:50 debug ALEOS_SERVICES_lpmmgr: main() LpmManager recv() received qMsgSize 48
Oct 18 18:56:50 debug ALEOS_SERVICES_lpmmgr: main() rxd message from CSM on LPM Manager queue
Oct 18 18:56:50 debug ALEOS_SERVICES_lpmmgr: ProcessMsciId() numIdsInMsg 1
Oct 18 18:56:50 debug ALEOS_SERVICES_lpmmgr: LpmMgrProcessTimers() called
Oct 18 18:57:00 debug ALEOS_SYSTEM_CSM: added 17000 - 0. to smio as rcdlen 9
Oct 18 18:57:00 debug ALEOS_SYSTEM_CSM: added 17100 - 0. to smio as rcdlen 9
Oct 18 18:57:00 debug ALEOS_SYSTEM_CSM: sent smio msg ret = 0
Oct 18 18:57:00 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17000) = “0”
Oct 18 18:57:00 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17100) = “0”
Oct 18 18:57:00 debug ALEOS_SYSTEM_CSM: added 55562 - 1697655420. to smio as rcdlen 18
Oct 18 18:57:00 debug ALEOS_SYSTEM_CSM: DATA_RSP
Oct 18 18:57:01 debug ALEOS_SYSTEM_CSM: added 17002 - 5. to smio as rcdlen 9
Oct 18 18:57:01 debug ALEOS_SYSTEM_CSM: added 17004 - 5. to smio as rcdlen 9
Oct 18 18:57:01 debug ALEOS_SYSTEM_CSM: added 17005 - 5. to smio as rcdlen 9
Oct 18 18:57:01 debug ALEOS_SYSTEM_CSM: added 17006 - 5. to smio as rcdlen 9
Oct 18 18:57:01 debug ALEOS_SYSTEM_CSM: added 17008 - 5. to smio as rcdlen 9
Oct 18 18:57:01 debug ALEOS_SYSTEM_CSM: added 17011 - 5. to smio as rcdlen 9
Oct 18 18:57:01 debug ALEOS_SYSTEM_CSM: added 17012 - 5. to smio as rcdlen 9
Oct 18 18:57:01 debug ALEOS_SYSTEM_CSM: added 17013 - 5. to smio as rcdlen 9
Oct 18 18:57:01 debug ALEOS_SYSTEM_CSM: added 17017 - 5. to smio as rcdlen 9
Oct 18 18:57:01 debug ALEOS_SYSTEM_CSM: sent smio msg ret = 0
Oct 18 18:57:01 alert ALEOS_SYSTEM_[logconfig]: ALEOS_LAN log level → ALEOS_NOTICE
Oct 18 18:57:01 alert ALEOS_SYSTEM_[logconfig]: ALEOS_SECURITY log level → ALEOS_NOTICE
Oct 18 18:57:01 alert ALEOS_SYSTEM_[logconfig]: ALEOS_SERVICES log level → ALEOS_NOTICE
Oct 18 18:57:01 alert ALEOS_SYSTEM_[logconfig]: ALEOS_EVENTS log level → ALEOS_NOTICE
Oct 18 18:57:01 alert ALEOS_SYSTEM_[logconfig]: ALEOS_APPS log level → ALEOS_NOTICE
Oct 18 18:57:01 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17002) = “5”
Oct 18 18:57:01 alert ALEOS_SYSTEM_[logconfig]: ALEOS_ADMIN log level → ALEOS_NOTICE
Oct 18 18:57:01 alert ALEOS_SYSTEM_[logconfig]: ALEOS_SYSTEM log level → ALEOS_NOTICE
Oct 18 18:57:01 alert ALEOS_SYSTEM_[logconfig]: ALEOS_NETSERV log level → ALEOS_NOTICE
Oct 18 18:57:01 debug ALEOS_SYSTEM_configMon: Configuration change detected: (17004) = “5”
Oct 18 18:57:01 alert ALEOS_SYSTEM_[logconfig]: ALEOS_CONNECTMGMT log level → ALEOS_NOTICE
What commands can be run to prove that the snmp service is on and reachable? Here are the logs from the firewall in front of the monitoring server showing that the connection is attempted.
Oct 18 2023 14:01:51: %ASA-7-609001: Built local-host inside:10.117.212.90
Oct 18 2023 14:01:51: %ASA-6-302015: Built inbound UDP connection 278395 for peer:192.168.11.40/63114 (192.168.11.40/63114) to inside:10.117.212.90/161 (10.117.212.90/161)
Hi @dflick,
Based on the logs I provided, I can’t be sure whether the issue is related to a hardware issue or a software issue.
According to the initial description, there were 40 devices working well, and if you’ve applied the template file from the working MP70 (with the same firmware) to the problematic MP70 device but cannot resolve the issue, it’s highly likely that it’s a specific issue.
In this case, it’s best for you to send an email to technical support at support@sierrawireless.com for assistance.
