Hello, I have a serial input and require the data to be sent to a PC on the router local area network. I have followed the instructions outlined in the ALEOS 4.6.1 config user guide for Airlink MP70, but no data is being received on the windows PC. Bytes received and sent increase as data is received on the MP70 serial port.
The PC connected on the LAN does not have the port blocked. FYI, the destination IP is 192.168.13.100, port 5000.
I have tried TCP, UDP and UDP Multpile Unicast and nothing is received by the windows PC.
I can successfully achieve Reverse Telnet. But no joy when configuring serial port startup mode for TCP, UDP, UDP Multpile Unicast.
Is serial port startup mode for TCP, UDP, UDP Multpile Unicast designed for sending data to a device on the router local are network? If so, is there something else that needs to be configured or set??
Thanks.
