Has anyone else had problems with the MG90 LTE-A part # 1102695 Reset to factory default settings not working?
Here is what I tried with no luck, things actually got worse when I tried the back reprogram/reset button.
After about 15 seconds of having the recessed Reset button near the cellular modem closure depressed, all the LEDs will quickly flash white, but did not stay white and reset the router config back to a default out-of-the-box type settings. It did not power off either. After waiting a couple minutes, I went ahead and just manually powered down the MG90, but still no luck.
I tried many different time periods of having that MG90 Reset button depressed such as 15s, 30s, 1min, 3min, and even 7 minutes with no results - still no solid white LEDs, power off, and associated factory reset to default values. By the way, 2 of the objects I used to depress that reset button were more than small enough for that little hole; so the button was fully depressed.
Since the front Reset button on the MG90 did not function properly to create a reset to factory defaults, I then tried the back reprogram/Reset button which created another problem. After depressing it for ~30 seconds, all communications with the MG90 were lost; so I disconnected power. Still no comms after plugging back the power cord; so I couldn’t even see the MG90 login website.
I redid this for about a minute the 2nd time, but again still no login website, nothing.
Anybody else had to reset an MG90 and noticed that the Reset function does not work with some MG90s?
