Does anyone know if this modem can detect a SIM insert/removal and set itself up without needing a power cycle?
I’m using AT!SIMNOTINSTALLED?, but it doesn’t seem to report when a SIM is inserted after the device has been powered up
Regards,
Mike
Check for the command AT^SYSINFO ,it return service status information.
AT^SYSINFO
Response: , , , ,
(SIM status):
• 0=SIM is not available
• 1=SIM is available
Thanks.
Thanks Rex_alex.
I’ve tried that commnad, but if I insert the SIM after the module has powered up, it never reports the SIM as present.
I was hoping I could use that command or similar to check if the SIM has been inserted or removed during operation… do you know if that is possible?
Mike
