Yes, I am actually using two modules that are exactly the same, with the same SW version. Both are plugged on the same board and I can access them on two different serial links. When I see the issue on one module, I have the issue on the second one.
When I restart the module (turn off, then turn on supply) and that I connect the module when it boots up, I issue the commands as follows :
AT
AT!ENTERCND=“A710”
AT!DAFTMACT
+CME ERROR: operation not supported
But for the moment I see no schematic or repeatability procedure.
Ok, I think I found the problem.
It must be related to the LPM ( Low Power mode). I deactivated it under Linux with the qmicli tool, set the power mode to online.
