I have just installed M2M on Vista 32 Home Premium. Started playing with the GUI and creating projects and files but the fly-outs on the second layer of the right click menu don’t appear intermittently. i.e. right click on the project and the menu appears - move over NEW> and the fly-out sometimes doesn’t appear. (The flyouts for RunAs, DebugAs, Team and Compare have never worked!) sometimes I get an error dialog - I can post the error log if it means anything to someone clever
I’m running M2M Build Version 1.1.0.200908120848
and Java 1.6.0_15
I have re-installed twice / restarted PC. Any ideas?
Al
Please just post the error log here.
Every time a right click menu fly-out doesn’t work this entry gets put in the error log. I also got an error dialog box but I clicked OK without reading it properly (sorry!) and that hasn’t happened again.
!ENTRY org.eclipse.ui 4 0 2009-10-01 23:13:32.512
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NullPointerException
at com.wavecom.openat.ide.ebs.build.core.MBSCoreUtils.isRteToolchain(MBSCoreUtils.java:194)
at com.wavecom.openat.ide.ebs.launch.rte.RTEPropertyTester.isRTE(RTEPropertyTester.java:76)
at com.wavecom.openat.ide.ebs.launch.rte.RTEPropertyTester.test(RTEPropertyTester.java:21)
at org.eclipse.core.internal.expressions.Property.test(Property.java:58)
at org.eclipse.core.internal.expressions.TestExpression.evaluate(TestExpression.java:99)
at org.eclipse.core.internal.expressions.CompositeExpression.evaluateOr(CompositeExpression.java:68)
at org.eclipse.core.internal.expressions.OrExpression.evaluate(OrExpression.java:21)
at org.eclipse.core.internal.expressions.CompositeExpression.evaluateAnd(CompositeExpression.java:53)
at org.eclipse.core.internal.expressions.IterateExpression.evaluate(IterateExpression.java:150)
at org.eclipse.core.internal.expressions.WithExpression.evaluate(WithExpression.java:72)
at org.eclipse.core.internal.expressions.EnablementExpression.evaluate(EnablementExpression.java:53)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchShortcutExtension.evalEnablementExpression(LaunchShortcutExtension.java:287)
at org.eclipse.debug.ui.actions.ContextualLaunchAction.isApplicable(ContextualLaunchAction.java:287)
at org.eclipse.debug.ui.actions.ContextualLaunchAction.fillMenu(ContextualLaunchAction.java:217)
at org.eclipse.debug.ui.actions.ContextualLaunchAction$1.menuShown(ContextualLaunchAction.java:136)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:235)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:770)
at org.eclipse.jface.action.ActionContributionItem.copyMenu(ActionContributionItem.java:1267)
at org.eclipse.jface.action.ActionContributionItem.handleShowProxy(ActionContributionItem.java:1247)
at org.eclipse.jface.action.ActionContributionItem.access$4(ActionContributionItem.java:1236)
at org.eclipse.jface.action.ActionContributionItem$8.handleEvent(ActionContributionItem.java:1209)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java:4111)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3815)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:337)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1576)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:1937)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4541)
at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:250)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:3849)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3416)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2200)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:490)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.wavecom.openat.ide.Application.start(Application.java:191)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
I’ve now updated my Java to the latest Java 6 update 16 - no change to the problem described before.
can anyone help me get the GUI working?
Here are a few more details from the log. I missed posting a few lines before + error dialog attached
!SESSION 2009-10-02 23:31:38.267 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_14
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86 -data @noDefault
!ENTRY org.eclipse.ui 2 0 2009-10-02 23:31:45.290
!MESSAGE Warnings while parsing the handlers from the ‘org.eclipse.ui.handlers’ extension point.
!SUBENTRY 1 org.eclipse.ui 2 0 2009-10-02 23:31:45.290
!MESSAGE Handlers need a class: plug-in=‘org.keplerproject.ldt.ui’, id=‘org.keplerproject.ldt.ui.handler1’
!ENTRY org.eclipse.osgi 2 0 2009-10-02 23:32:04.244
!MESSAGE While loading class “org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListener”, thread “Thread[Worker-6,5,main]” timed out waiting (5000ms) for thread “Thread[Worker-0,5,main]” to finish starting bundle “reference:file:plugins/org.eclipse.rse.ui_3.0.3.v200902042310.jar [178]”. To avoid deadlock, thread “Thread[Worker-6,5,main]” is proceeding but “org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListener” may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle “reference:file:plugins/org.eclipse.rse.ui_3.0.3.v200902042310.jar” by thread “Worker-0”.
at org.eclipse.osgi.framework.internal.core.AbstractBundle.beginStateChange(AbstractBundle.java:1144)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:263)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:400)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:427)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:193)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:370)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java:446)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:399)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.rse.ui.SystemPreferencesManager$1.run(SystemPreferencesManager.java:510)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Caused by: org.eclipse.osgi.framework.internal.core.AbstractBundle$BundleStatusException
… 15 more
Root exception:
!ENTRY org.eclipse.ui 4 0 2009-10-02 23:32:16.527
!STACK 0
also have a problem with showing Project | Properties | Run/DebugSettings an error dialog pops up.
error log:
!ENTRY org.eclipse.jface 4 2 2009-10-03 20:31:27.060
!MESSAGE Problems occurred when invoking code from plug-in: “org.eclipse.jface”.
!STACK 0
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationManager.getApplicableConfigurationTypes(LaunchConfigurationManager.java:736)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationManager.getApplicableLaunchConfigurations(LaunchConfigurationManager.java:772)
at org.eclipse.debug.internal.ui.preferences.RunDebugPropertiesPage.collectConfigCandidates(RunDebugPropertiesPage.java:272)
at org.eclipse.debug.internal.ui.preferences.RunDebugPropertiesPage.createContents(RunDebugPropertiesPage.java:110)
at org.eclipse.jface.preference.PreferencePage.createControl(PreferencePage.java:235)
at org.eclipse.jface.preference.PreferenceDialog.createPageControl(PreferenceDialog.java:1468)
at org.eclipse.jface.preference.PreferenceDialog$14.run(PreferenceDialog.java:1225)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.preference.PreferenceDialog.showPage(PreferenceDialog.java:1219)
at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.showPage(FilteredPreferenceDialog.java:682)
at org.eclipse.jface.preference.PreferenceDialog$10.run(PreferenceDialog.java:702)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.jface.preference.PreferenceDialog$9.selectionChanged(PreferenceDialog.java:698)
at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:842)
at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java:840)
at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(StructuredViewer.java:1153)
at org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected(StructuredViewer.java:1178)
at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(OpenStrategy.java:250)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:244)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java:418)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3425)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDialogAction.java:157)
at org.eclipse.ui.internal.ide.actions.ProjectPropertyDialogAction.run(ProjectPropertyDialogAction.java:77)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:583)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:500)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422)
Thanks for all your feedback.
The issue is reproduced on our side (and will be fixed in next release), but only when right-clicking on C/C++ projects which are not Open AT projects.
Please make sure that you create projects thanks to the New Open AT project wizard, and not from the New C (or C++) project wizard.
I’ll check I’m setting it up OK…
