I have a shortcut in my desktop to M2M 1.1.1, and everytime I close it, it creates a .log file with this:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x61183361, pid=3864, tid=3408
# JRE version: 6.0_14-b08
# Java VM: Java HotSpot(TM) Client VM (14.0-b16 mixed mode windows-x86 )
# Problematic frame:
# C [pthreadGC2.dll+0x3361]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x2b793800): JavaThread "TCF Output Process of peer LOCALHOST" daemon [_thread_in_native, id=3408, stack(0x331e0000,0x332e0000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000008
Registers:
EAX=0x61183350, EBX=0x00000000, ECX=0x00000000, EDX=0x69b86100
ESP=0x332dd7a0, EBP=0x332dd7a8, ESI=0x00000000, EDI=0x2b793800
EIP=0x61183361, EFLAGS=0x00010213
Top of Stack: (sp=0x332dd7a0)
0x332dd7a0: 2562b9b0 2562b9b0 332dd7c8 69b41789
0x332dd7b0: 69b86100 6d900696 2b793800 0001c8a9
0x332dd7c0: 0001c899 00000010 332df818 69b42397
0x332dd7d0: 332dd7f0 00000010 00000000 00000000
0x332dd7e0: 00000000 00000000 00000000 00000010
0x332dd7f0: 0000ffaa 00000000 00000000 00000000
0x332dd800: 02000004 00000000 00000000 00000000
0x332dd810: 00000000 00000000 00000000 00000000
Instructions: (pc=0x61183361)
0x61183351: 89 e5 56 53 31 f6 8b 55 08 8b 1a 83 fb fc 77 3f
0x61183361: 8b 43 08 85 c0 75 58 8b 15 24 80 18 61 85 d2 74
Stack: [0x331e0000,0x332e0000], sp=0x332dd7a0, free space=1013k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libSelimaInterface.dll+0x1789]
C [libSelimaInterface.dll+0x2397]
j com.wavecom.openat.ide.wcc.selima.SelimaDriver.write([I)V+0
J com.wavecom.openat.ide.wcc.tcf.extensions.channel.SelimaChannel.writeMessage([Lcom/anyware/tm/tcf/extender/message/IMessage;)V
J com.anyware.tm.tcf.extensions.channel.AbstractChannel.outProcess()V
j com.anyware.tm.tcf.extensions.channel.AbstractChannel.access$1(Lcom/anyware/tm/tcf/extensions/channel/AbstractChannel;)V+1
j com.anyware.tm.tcf.extensions.channel.AbstractChannel$2.run()V+4
v ~StubRoutines::call_stub
V [jvm.dll+0xecabc]
V [jvm.dll+0x173d61]
V [jvm.dll+0xecc87]
V [jvm.dll+0xeccfd]
V [jvm.dll+0x115d60]
V [jvm.dll+0x1cfd44]
V [jvm.dll+0x1739dc]
C [MSVCR71.dll+0xb381]
C [kernel32.dll+0xb729]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x2dd33400 JavaThread "Worker-36" [_thread_blocked, id=4332, stack(0x33510000,0x33610000)]
0x2deb9000 JavaThread "WCM ShellOutputReaderThread-1651" [_thread_blocked, id=3772, stack(0x37910000,0x37a10000)]
0x2def8800 JavaThread "Worker-35" [_thread_blocked, id=5056, stack(0x36b00000,0x36c00000)]
0x2ddd6800 JavaThread "Worker-34" [_thread_blocked, id=4424, stack(0x35f20000,0x36020000)]
0x2deaf800 JavaThread "Worker-33" [_thread_blocked, id=5016, stack(0x2ea20000,0x2eb20000)]
=>0x2b793800 JavaThread "TCF Output Process of peer LOCALHOST" daemon [_thread_in_native, id=3408, stack(0x331e0000,0x332e0000)]
0x2c135800 JavaThread "TCF Input Process of peer LOCALHOST" daemon [_thread_in_native, id=4760, stack(0x32eb0000,0x32fb0000)]
0x2d950000 JavaThread "Worker-30" [_thread_blocked, id=4532, stack(0x33410000,0x33510000)]
0x2de59c00 JavaThread "WCM ShellOutputReaderThread-1643" [_thread_blocked, id=5532, stack(0x36220000,0x36320000)]
0x2de92000 JavaThread "Process monitor" daemon [_thread_blocked, id=5344, stack(0x353a0000,0x354a0000)]
0x2d936400 JavaThread "Output Stream Monitor" daemon [_thread_blocked, id=3412, stack(0x350a0000,0x351a0000)]
0x2ddaf800 JavaThread "MI Event Thread" [_thread_in_native, id=3804, stack(0x34fa0000,0x350a0000)]
0x2d939c00 JavaThread "MI RX Thread" [_thread_in_native, id=456, stack(0x34da0000,0x34ea0000)]
0x2b799c00 JavaThread "Spawner Reaper" daemon [_thread_in_native, id=5976, stack(0x33910000,0x33a10000)]
0x2ddb8400 JavaThread "Worker-24" [_thread_blocked, id=3876, stack(0x332e0000,0x333e0000)]
0x2ddb6400 JavaThread "Worker-21" [_thread_blocked, id=5008, stack(0x31cb0000,0x31db0000)]
0x2dcca000 JavaThread "Worker-20" [_thread_blocked, id=5968, stack(0x31eb0000,0x31fb0000)]
0x2deb7800 JavaThread "WCM ShellOutputReaderThread-13" [_thread_blocked, id=4112, stack(0x31db0000,0x31eb0000)]
0x2dc67400 JavaThread "TCF Tasks Dispatch" daemon [_thread_blocked, id=3024, stack(0x2e8d0000,0x2e9d0000)]
0x2db95400 JavaThread "MultiThreadedHttpConnectionManager cleanup" daemon [_thread_blocked, id=3216, stack(0x2f0d0000,0x2f1d0000)]
0x2da78400 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=2872, stack(0x2efd0000,0x2f0d0000)]
0x2d93f400 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=6020, stack(0x2e4e0000,0x2e5e0000)]
0x2c2ca800 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=2956, stack(0x2e100000,0x2e200000)]
0x2bf0cc00 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=4720, stack(0x2c3f0000,0x2c4f0000)]
0x2b6f2800 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=4508, stack(0x2bdf0000,0x2bef0000)]
0x2ae5a800 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=4500, stack(0x2bcf0000,0x2bdf0000)]
0x2b6e7000 JavaThread "State Data Manager" daemon [_thread_blocked, id=2876, stack(0x2bbf0000,0x2bcf0000)]
0x2ae40c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=5688, stack(0x2b4b0000,0x2b5b0000)]
0x2ae3b000 JavaThread "CompilerThread0" daemon [_thread_blocked, id=5684, stack(0x2b3b0000,0x2b4b0000)]
0x2ae39800 JavaThread "Attach Listener" daemon [_thread_blocked, id=2708, stack(0x2b2b0000,0x2b3b0000)]
0x2ae38400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=5564, stack(0x2b1b0000,0x2b2b0000)]
0x2ae28000 JavaThread "Finalizer" daemon [_thread_blocked, id=5536, stack(0x2b0b0000,0x2b1b0000)]
0x2ae23800 JavaThread "Reference Handler" daemon [_thread_blocked, id=5540, stack(0x2afb0000,0x2b0b0000)]
0x003c6c00 JavaThread "main" [_thread_blocked, id=5004, stack(0x00040000,0x00140000)]
Other Threads:
0x2ae20400 VMThread [stack: 0x2aeb0000,0x2afb0000] [id=5444]
0x2ae4b400 WatcherThread [stack: 0x2b5b0000,0x2b6b0000] [id=5692]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 9216K, used 2165K [0x02b20000, 0x03510000, 0x05280000)
eden space 8256K, 16% used [0x02b20000, 0x02c6dcd0, 0x03330000)
from space 960K, 86% used [0x03420000, 0x034ef730, 0x03510000)
to space 960K, 0% used [0x03330000, 0x03330000, 0x03420000)
tenured generation total 121024K, used 103480K [0x05280000, 0x0c8b0000, 0x22b20000)
the space 121024K, 85% used [0x05280000, 0x0b78e248, 0x0b78e400, 0x0c8b0000)
compacting perm gen total 64000K, used 63825K [0x22b20000, 0x269a0000, 0x2ab20000)
the space 64000K, 99% used [0x22b20000, 0x26974448, 0x26974600, 0x269a0000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0040e000 C:\Program Files\Sierra Wireless\m2mstudio\m2mstudio.exe
0x7c910000 - 0x7c9c8000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c903000 C:\WINDOWS\system32\kernel32.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77ef0000 - 0x77f39000 C:\WINDOWS\system32\GDI32.dll
0x773a0000 - 0x774a3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\COMCTL32.dll
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x77da0000 - 0x77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee2000 C:\WINDOWS\system32\RPCRT4.dll
0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
0x76340000 - 0x7635d000 C:\WINDOWS\system32\IMM32.DLL
0x72000000 - 0x72014000 C:\Program Files\Sierra Wireless\m2mstudio\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x6d800000 - 0x6da8b000 C:\Program Files\Sierra Wireless\m2mstudio\jre\bin\client\jvm.dll
0x76b00000 - 0x76b2e000 C:\WINDOWS\system32\WINMM.dll
0x7c360000 - 0x7c3b6000 C:\WINDOWS\system32\MSVCR71.dll
0x6d7b0000 - 0x6d7bc000 C:\Program Files\Sierra Wireless\m2mstudio\jre\bin\verify.dll
0x6d330000 - 0x6d34f000 C:\Program Files\Sierra Wireless\m2mstudio\jre\bin\java.dll
0x6d290000 - 0x6d298000 C:\Program Files\Sierra Wireless\m2mstudio\jre\bin\hpi.dll
0x76bb0000 - 0x76bbb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d7f0000 - 0x6d7ff000 C:\Program Files\Sierra Wireless\m2mstudio\jre\bin\zip.dll
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x76630000 - 0x766e5000 C:\WINDOWS\system32\USERENV.dll
0x597f0000 - 0x59845000 C:\WINDOWS\system32\netapi32.dll
0x6d610000 - 0x6d623000 C:\Program Files\Sierra Wireless\m2mstudio\jre\bin\net.dll
0x71a30000 - 0x71a47000 C:\WINDOWS\system32\WS2_32.dll
0x71a20000 - 0x71a28000 C:\WINDOWS\system32\WS2HELP.dll
0x719d0000 - 0x71a10000 C:\WINDOWS\System32\mswsock.dll
0x76ee0000 - 0x76f07000 C:\WINDOWS\system32\DNSAPI.dll
0x76f70000 - 0x76f78000 C:\WINDOWS\System32\winrnr.dll
0x76f20000 - 0x76f4d000 C:\WINDOWS\system32\WLDAP32.dll
0x76f80000 - 0x76f86000 C:\WINDOWS\system32\rasadhlp.dll
0x5b150000 - 0x5b188000 C:\WINDOWS\system32\uxtheme.dll
0x746b0000 - 0x746fc000 C:\WINDOWS\system32\MSCTF.dll
0x77b10000 - 0x77b32000 C:\WINDOWS\system32\apphelp.dll
0x75160000 - 0x7518e000 C:\WINDOWS\system32\msctfime.ime
0x774b0000 - 0x775ed000 C:\WINDOWS\system32\ole32.dll
0x6d630000 - 0x6d639000 C:\Program Files\Sierra Wireless\m2mstudio\jre\bin\nio.dll
0x2c2f0000 - 0x2c349000 C:\Program Files\Sierra Wireless\m2mstudio\configuration\org.eclipse.osgi\bundles\199\1\.cp\swt-win32-3550.dll
0x770f0000 - 0x7717b000 C:\WINDOWS\system32\OLEAUT32.dll
0x76360000 - 0x763aa000 C:\WINDOWS\system32\comdlg32.dll
0x7e6a0000 - 0x7eec1000 C:\WINDOWS\system32\SHELL32.dll
0x74d20000 - 0x74d8b000 C:\WINDOWS\system32\USP10.dll
0x3fa00000 - 0x3fad1000 C:\WINDOWS\system32\WININET.dll
0x2bbb0000 - 0x2bbb9000 C:\WINDOWS\system32\Normaliz.dll
0x400a0000 - 0x400e5000 C:\WINDOWS\system32\iertutil.dll
0x2c390000 - 0x2c3a4000 C:\Program Files\Sierra Wireless\m2mstudio\configuration\org.eclipse.osgi\bundles\199\1\.cp\swt-gdip-win32-3550.dll
0x4eba0000 - 0x4ed4b000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6001.22319_x-ww_f0b4c2df\gdiplus.dll
0x66740000 - 0x66799000 C:\WINDOWS\system32\hnetcfg.dll
0x71a10000 - 0x71a18000 C:\WINDOWS\System32\wshtcpip.dll
0x2c3e0000 - 0x2c3e8000 C:\Program Files\Sierra Wireless\m2mstudio\configuration\org.eclipse.osgi\bundles\90\1\.cp\os\win32\x86\localfile_1_0_0.dll
0x74c10000 - 0x74c3c000 C:\WINDOWS\system32\oleacc.dll
0x76030000 - 0x76095000 C:\WINDOWS\system32\MSVCP60.dll
0x2d420000 - 0x2d6f6000 C:\WINDOWS\system32\xpsp2res.dll
0x76f90000 - 0x7700f000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77010000 - 0x770e0000 C:\WINDOWS\system32\COMRes.dll
0x75dd0000 - 0x75e61000 C:\WINDOWS\system32\mlang.dll
0x2b9e0000 - 0x2b9ef000 C:\Program Files\Sierra Wireless\m2mstudio\configuration\org.eclipse.osgi\bundles\93\1\.cp\jWinHttp-1.0.0.dll
0x4d550000 - 0x4d5a9000 C:\WINDOWS\system32\WINHTTP.dll
0x76ea0000 - 0x76edc000 C:\WINDOWS\system32\RASAPI32.DLL
0x76e50000 - 0x76e62000 C:\WINDOWS\system32\rasman.dll
0x76e70000 - 0x76e9f000 C:\WINDOWS\system32\TAPI32.dll
0x76e40000 - 0x76e4e000 C:\WINDOWS\system32\rtutils.dll
0x77c40000 - 0x77c65000 C:\WINDOWS\system32\msv1_0.dll
0x76750000 - 0x7675c000 C:\WINDOWS\system32\cryptdll.dll
0x76d20000 - 0x76d39000 C:\WINDOWS\system32\iphlpapi.dll
0x76330000 - 0x76335000 C:\WINDOWS\system32\msimg32.dll
0x2ecd0000 - 0x2ed30000 C:\Program Files\Sierra Wireless\m2mstudio\plugins\com.wavecom.openat.ide.wcc.selima_1.1.1.200911160856-R3160\MSVCRTD.DLL
0x5f400000 - 0x5f4e5000 C:\Program Files\Sierra Wireless\m2mstudio\plugins\com.wavecom.openat.ide.wcc.selima_1.1.1.200911160856-R3160\MFC42D.DLL
0x61df0000 - 0x61dfe000 C:\WINDOWS\system32\MFC42LOC.DLL
0x5f500000 - 0x5f5c5000 C:\Program Files\Sierra Wireless\m2mstudio\plugins\com.wavecom.openat.ide.wcc.selima_1.1.1.200911160856-R3160\MFCO42D.DLL
0x61180000 - 0x6118e000 C:\Program Files\Sierra Wireless\m2mstudio\plugins\com.wavecom.openat.ide.wcc.selima_1.1.1.200911160856-R3160\pthreadGC2.dll
0x71a50000 - 0x71a5a000 C:\WINDOWS\system32\WSOCK32.DLL
0x2e610000 - 0x2e61e000 C:\Program Files\Sierra Wireless\m2mstudio\plugins\com.wavecom.openat.ide.wcc.selima_1.1.1.200911160856-R3160\SelimaDriverLib.dll
0x73d50000 - 0x73e4e000 C:\WINDOWS\system32\MFC42.DLL
0x69b40000 - 0x69b93000 C:\Program Files\Sierra Wireless\m2mstudio\plugins\com.wavecom.openat.ide.wcc.selima_1.1.1.200911160856-R3160\libSelimaInterface.dll
0x2f6d0000 - 0x2fb11000 C:\WINDOWS\system32\msi.dll
0x76980000 - 0x76a31000 C:\WINDOWS\system32\SXS.DLL
0x647c0000 - 0x647c8000 C:\Program Files\Sierra Wireless\m2mstudio\plugins\org.eclipse.cdt.core.win32_5.1.0.200906161748\os\win32\x86\winreg.dll
0x6e7c0000 - 0x6e7ca000 C:\Program Files\Sierra Wireless\m2mstudio\plugins\org.eclipse.cdt.core.win32_5.1.0.200906161748\os\win32\x86\spawner.dll
0x44430000 - 0x44558000 C:\WINDOWS\system32\urlmon.dll
0x778f0000 - 0x779e7000 C:\WINDOWS\system32\SETUPAPI.dll
0x74680000 - 0x746aa000 C:\WINDOWS\system32\msimtf.dll
0x31290000 - 0x312a7000 C:\Archivos de programa\Archivos comunes\TortoiseOverlays\TortoiseOverlays.dll
0x31350000 - 0x3135e000 C:\Archivos de programa\TortoiseSVN\bin\TortoiseStub.dll
0x31a10000 - 0x31ad8000 C:\Archivos de programa\TortoiseSVN\bin\TortoiseSVN.dll
0x76740000 - 0x76749000 C:\WINDOWS\system32\SHFOLDER.dll
0x6eec0000 - 0x6eee2000 C:\Archivos de programa\TortoiseSVN\bin\libapr_tsvn.dll
0x78520000 - 0x785c3000 C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e\MSVCR90.dll
0x6ee60000 - 0x6ee8f000 C:\Archivos de programa\TortoiseSVN\bin\libaprutil_tsvn.dll
0x31b10000 - 0x31b22000 C:\Archivos de programa\TortoiseSVN\bin\intl3_tsvn.dll
0x78480000 - 0x7850e000 C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e\MSVCP90.dll
0x77a50000 - 0x77ae6000 C:\WINDOWS\system32\CRYPT32.dll
0x77af0000 - 0x77b02000 C:\WINDOWS\system32\MSASN1.dll
0x661d0000 - 0x663ef000 C:\Archivos de programa\Microsoft Office\Office12\GrooveShellExtensions.dll
0x68ef0000 - 0x68fe2000 C:\Archivos de programa\Microsoft Office\Office12\GrooveUtil.DLL
0x78130000 - 0x781cb000 C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\MSVCR80.dll
0x68ff0000 - 0x68ff7000 C:\Archivos de programa\Microsoft Office\Office12\GrooveNew.DLL
0x7c630000 - 0x7c64b000 C:\WINDOWS\WinSxS\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_473666fd\ATL80.DLL
VM Arguments:
jvm_args: -Xms128m -Xmx512m -XX:MaxPermSize=128m -XX:+HeapDumpOnOutOfMemoryError
java_command: <unknown>
Launcher Type: generic
Environment Variables:
CLASSPATH=.;C:\Archivos de programa\Java\jre1.6.0_03\lib\ext\QTJava.zip
PATH=C:/Program Files/Sierra Wireless/m2mstudio/jre/bin/client;C:/Program Files/Sierra Wireless/m2mstudio/jre/bin;C:\Archivos de programa\PC Connectivity Solution\;C:\oraclexe\app\oracle\product\10.2.0\server\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;c:\Archivos de programa\Microsoft SQL Server\90\Tools\binn\;C:\Archivos de programa\QuickTime\QTSystem\;C:\Archivos de programa\TortoiseSVN\bin;C:\Archivos de programa\7T\IGSS32\V7.0\gss;C:\WINDOWS\system32\WindowsPowerShell\v1.0;c:\Archivos de programa\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;c:\Archivos de programa\Microsoft SQL Server\100\Tools\Binn\;c:\Archivos de programa\Microsoft SQL Server\100\DTS\Binn\
USERNAME=Xavier Navarro
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 6 Stepping 4, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 2 (2 cores per cpu, 1 threads per core) family 15 model 6 stepping 4, cmov, cx8, fxsr, mmx, sse, sse2, sse3
Memory: 4k page, physical 2097151k(1963356k free), swap 4194303k(2881964k free)
vm_info: Java HotSpot(TM) Client VM (14.0-b16) for windows-x86 JRE (1.6.0_14-b08), built on May 21 2009 08:03:56 by "java_re" with MS VC++ 7.1
time: Wed Dec 09 17:19:43 2009
elapsed time: 5648 seconds
I just delete the files but…
