[LX40] Port forward not working
Hi all,
I have an AirLink LX40, connected via a switch to a BeagleBone Black (BBB). I have a server running on the BBB on port 80, and I can access it when I connect my computer to the switch. The installation is exactly as follows:
I am trying to configure a port forward from the LX40 to the BBB. I am using ALEOS 4.13.0. The configuration of the LX40 is as follows:
Unfortunately, locally (when I connect my computer the switch, 10.0.0.1:8080) and from the WAN (with the IP given from the status page, X.X.X.X:8080), I am unable to access the server on the BBB.
I would appreciate some advice.
Thanks in advance for your help.
Hi Jeremy,
Your server is running on port 80, but why did you access locally via 10.0.0.1:8080 ?
Please make sure the port of server is 80 or 8080.
If you can connect to server with 8080 port, you should configure Private Start Port on Port Forwarding 8080.
