LTE don’t work with MC7354.
I have try it with ATT and VZW firmware.
I use CMW500 to emulator LTE network band2.
Downlink channel as 900 Ch.
Cell bandwidth as 5MHz.
why LTE can’t work?
why LTE can’t work?
Check the band configuration and also the selrat
AT!BAND?
AT!SELRAT?
I think that the supported LTE bands depend on the carrier pri
AT!BAND?
Index, Name, GW Band Mask L Band Mask
00, All Bands, 000200000CE80380 0000000000010008
AT!SELRAT?
!SELRAT: 00, Automatic
I think GW Band support:
• 0000000000000080—G1800
• 0000000000000300—G900 (EGSM/GSM)
• 0000000000080000—G850
• 0000000000200000—G1900
• 0000000000400000—W2100
• 0000000000800000—W1900
• 0000000004000000—W850
• 0000000008000000—W800
• 0002000000000000—W900
But I am not sure LTE band.
MC7354 should support Band2, Band4 (AWS), Band5, Band13, Band17, Band25, this come from MC734 document.
I don’t know whether the return band for LTE is same with supportted bands?
Device can search WCDMA/GSM network only with ATT firmware.
Do I need change other firmware?
AT!BAND? indicate that only LTE band 4 and 17 are supported.
