Is there a way to connect SPI or I2C to Octave?
Hi, I was wondering if there’s a way to connect SPI or I2C to Octave using the MangOH Yellow?
-Ray
Unfortunately, I2C and SPI are not supported out the box in Octave / MangOH yellow today.
Since it’s not supported directly, I was wondering if anyone knows a possible workaround for this issue?
Not at this stage with Octave. No workaround. You need to find a different solution ( mangoh yellow/Legato maybe on legato.io ?)
You can also use SPI or I2C to serial adapter in your architecture and then utilize the USP or ORP service
