Connect a serial input for Keyboard
We would like to Connect a numeric keypad using USB serial (or RS232/xxx) to the MangOH yellow device to receive user keystroke inputs as a string so that we can process the data on the edge.
Is this currently supported? and if so, what is the easiest and/or best way to achieve this?
The requirement is to capture a numeric input at the edge and send it to the cloud. Any pointers will be appreciated whether we should look at USB to UART or GPIO and also at a high level how this can be achieved.
Thanks in advance
Theo
Hi Theo
In order to support a USB keyboard you would need
  1. The Linux driver (might already be built into the WP7702 OS)
  2. A Legato app to handle the USB keyboard data and send it to the Legato Datahub
  3. Access to Sierra’s Edge Octave binary images
  4. The Legato build system
A tricky project.
An alternative is to connect a serial (UART based) keyboard to the mangOH yellow UART1 via the (1V8 logic) IoT expansion board. You will need a voltage level shifter to interface the keyboard with the mangOH - if using an RS232 keyboard you will need an RS232 converter that interfaces with 1V8 logic. In order to achieve this with standard parts off the net you will probably need a RS232 <> 3V3 and 3V3 <> 1V8 level shifter
In Octave you could use the USP protocol to capture the keyboard data and then an edge action to process it
I hope this helps
John
Hi Theo,
Are you familiar with out Universal Serial Parser? It is in preview on the 3.0.x releases:
If you are willing to use RS232, then perhaps this will work for you.
Ian
Thank you John and Ian, for the responses. You guys have given me something the work with. I will report back shortly on my progress.
