Include Files
Hi All,
Wondering if any of you could help me with a very basic question.
I’m having a bit of trouble trying to build external source code into my application. I’ve specified -inc in my Project Wizard “wmnew script additional settings”, and when I compile, it manages to find the first file I try to include, but when that file tries to include another file in the same directory, it can’t find it. What am I doing wrong? How can I set up global include paths for the entire build?
Sorry if this seems like a very elementary question. I can’t find anything in any of the manuals that I have (maybe I don’t have all of them?), and searching the forums gives me massive amounts of results, but nothing relevant.
Also I’ve noticed the Tools Manual is mentioned a lot on this forum, but nobody mentions where I can find it. The website search comes up with nothing.
Nick
The tools manual is in OpenAT/IDE/IDE//doc/TM_Tools_Manual_for_Open_AT.pdf
Are you trying to include a files that doesn’t have the .h extension? The documentation seems to imply that it only copies the .h files to ./{compiler}/out/.
Anyway, the solution I think you’re looking for is to use the -noppinc parameter when calling wmnew instead of using -inc.
No they’re .h extension. The -noppinc option works - thanks! We’re actually trying to get C++ / STL working, though I’m beginning to wonder whether it’s a good idea. I’ve got C++ to work, but I can’t get STL to compile - even the
new
operator isn’t linked in, so I’m not sure I’ve got all the libraries linking properly. Maybe it’s not such a good idea, but we were hoping to just port some software over, so it would be less work than rewriting it in C.
Nick
the Open AT IDE (before M2MStudio) has a couple of puzzling “features”. Among others, it preprocesses your header files and puts all resulting header files in a single directory. Worse thing is, this preprocessor does nothing on user application code, so it basically is an extremely slow file copy! As a result, if you specify file paths within your #include directives, you’re screwed. For some reason, it also hates the angles brackets in #include< >, so you should change them into quotes #include " ". It tries to build dependencies automatically, but fails in complex case (i.e. when there are several files and/or dependencies between them! :open_mouth: :smiley: ), so you’d spend ridiculous amounts of time debugging the system, based on scripts-that-generate-makefiles-depending-on-a-dozen-of-submakefiles-to-finally-generate-a-script-that-only-works-on-a-single-deprecated-version-of-cygwin. Of course, in addition to usually fail at one point or another, this contraption takes amazingly long to do so. I must have forgotten many other quirks of the system, but the final result is that I’m, as many other people, unable to use it for anything non-trivial. Plus, given that Wavecom is releasing a new IDE remade from scratch, you shouldn’t expect a fix for the old one.
If you want to do something more complex than changing a couple of lines in a Wavecom-provided sample, you cannot rely on the provided build system; search this forum for “minimalist makefiles” and start from there.
