I use adl_L3infoSubscribe() API to subscribe a ADL_L3INFO_CELL or ADL_L3INFO_SCAN handler, but it return -13, which means my WCPU can not support the function,
my WCPU: Q2687G
firmware version: R71_00gg.Q2687G
OS version: 06.02
for This WCPU, it should support that function, does any body can help me, or give me some advice? how can I get the PLMN and RSSI info in WCPU?
Thanks for any help.
Please don’t cross-post the same entry to multiple forums. It just annoys people
Have you checked the result of AT+WCFM=5 - the Layer 3 functionality is an extra commercial feature that has to be enabled by Wavecom.
See the AT Command Interface Guide, section 6.5 (this is for firmware R7.4 - other versions may be different) for info on decoding the output of the AT+WCFM command.
If the Layer 3 functionality is not enabled, you will have to contact your distributor to pay for the updates to your modem.
yes, we can get some PLMN info by AT command,
I want to get the MCC,MNC and RSSI, My question is how to get those info inside WCPU via APIs directly, not send AT command to WCPU and WCPU reponse the result.
I want to get and indicate those info by WCPU, like PLMN_Scan example do.
Do you have any ideal how to send AT command inside WCPU and get response by itself?
Thanks for any help!
at+wcfm=5
+WCFM: 00000471,0
at+wcfm=2
+WCFM: 0166,0
the AT user guide (firmware R71) decode explain as following, as if my WCPU can not support the PLMN scan function.
: requested operation
0 disable some features of
1 enable some features of
2 display the features state
3 disable some extended commercial features of
4 enable some extended commercial features of
5 display the extended commercial features state
: features mask
16 bits hexadecimal string
commercial features ( =0, =1 or
=2) :
02 GPRS Class 2
04 Wireless CPU® Highest GPRS CLASS allowed
10 Open AT® Bluetooth Plug In
20 Echo Cancellation Algorithm
40 EDGE (EGPRS)
80 Wavecom debug feature
200 DOTA 3
400 IDS Third Server
extended commercial features ( =3, =4 or
=5) :
01 Internet Plug In
02 MQTT: IBM Websphere
04 ORANGE M2M Connect
08 Open AT® GTI Plug In
10 Real Time Operating System
20 Open Sim Access
40 Open AT® C-GPS Plug In
400 Watchdog
Yes - read the section in the ADL User Guide about AT Commands!
Please note the ‘QUOTE’ button that appears in the top-left of each and every post on the forums - if you want to quote a previous thread, just press the ‘QUOTE’ button, and it will start a reply with that message quoted.
Edit that quote as required to leave only the relevant portion…
