How to customise gcc.lkopt ?
#1
See: https://forum.sierrawireless.com/t/persistent-ram-adl-mem-uninit/3836/5
gcc.lkopt seems to be automatically generated by the build - so where does it actually come from?
where are the inputs & options from which it is created?
#2
gcc.lkopt is indeed generated automatically by the Studio.
But you can workaround that by, for example making a copy of the script at project’s root directory (e.g. mygcc.lkopt), and edit it as you want.
Then in the project options, go to project properties > C/C++ Build > Settings > ARM ELF GCC C++ Linker
In the command line pattern, you get something like:
${COMMAND} -Wl,--script,gcc.lkopt ......
Just modify it:
${COMMAND} -Wl,--script,../mygcc.lkopt ......
And the linker will use the custom script.
#3
I made the change, but the build is now grindingly slow!
It sticks in dd.exe for ages, and genbin.exe for a long time.
And, once the actual build has finished, it then spends a load more time “refreshing workspace”
#4
Probably because the .axf file has shot up to ~400MB - yes, Mega Bytes!! :open_mouth:
#5
See: https://forum.sierrawireless.com/t/whats-wrong-with-this-linker-script/4598/1
