OK - I’ve been using objdump -p -h to see the sections in the .axf file.
For the “standard” M2MStudio linker script (giving ~10MB .axf file and ~300KB .bin), it shows:
cbox_424.axf: file format elf32-littlearm
Program Header:
LOAD off 0x00000054 vaddr 0x00210000 paddr 0x00210000 align 2**2
filesz 0x0004798c memsz 0x00052568 flags rwx
private flags = 206: [interworking enabled] [APCS-32] [FPA float format] [software FP] [has entry point]
Sections:
Idx Name Size VMA LMA File off Algn
0 .oat_header 0000003c 00210000 00210000 00000054 2**2
CONTENTS, ALLOC, LOAD, READONLY, DATA
1 .text 00046ddc 0021003c 0021003c 00000090 2**2
CONTENTS, ALLOC, LOAD, READONLY, CODE
2 .data 00000b74 180c0000 00256e18 00046e6c 2**2
CONTENTS, ALLOC, LOAD, DATA
3 .bss 0000abdc 180c0b74 180c0b74 000479e0 2**2
ALLOC
4 .uninit 00000000 180cb750 180cb750 000479e0 2**0
CONTENTS
5 .debug_abbrev 00018e3f 00000000 00000000 000479e0 2**0
CONTENTS, READONLY, DEBUGGING
6 .debug_info 0008dfde 00000000 00000000 0006081f 2**0
7 .debug_line 0005a06d 00000000 00000000 000ee7fd 2**0
8 .debug_macinfo 0072b309 00000000 00000000 0014886a 2**0
9 .debug_pubnames 000066b2 00000000 00000000 00873b73 2**0
10 .debug_str 00014fd7 00000000 00000000 0087a225 2**0
11 .comment 0000142e 00000000 00000000 0088f1fc 2**0
CONTENTS, READONLY
12 .debug_frame 000097cc 00000000 00000000 0089062c 2**2
13 .debug_loc 0003ba19 00000000 00000000 00899df8 2**0
14 .debug_aranges 00002360 00000000 00000000 008d5818 2**3
15 .debug_ranges 00002c60 00000000 00000000 008d7b78 2**0
Note the “filesz 0x0004798c memsz 0x00052568” (ie, 293260 and 337256).
With the script modified to move the .uninit section definition before the .data section (giving ~400MB .axf file and ~400MB .bin), it shows:
Program Header:
filesz 0x17eb0b80 memsz 0x17ebb768 flags rwx
Sections:
1 .text 00046ee8 0021003c 0021003c 00000090 2**2
2 .uninit 0000000c 180c0000 180c0000 00046f78 2**2
ALLOC
3 .data 00000b74 180c000c 180c000c 17eb006c 2**2
4 .bss 0000abdc 180c0b80 180c0b80 17eb0be0 2**2
ALLOC
5 .debug_abbrev 00018e3f 00000000 00000000 17eb0be0 2**0
6 .debug_info 0008dff2 00000000 00000000 17ec9a1f 2**0
7 .debug_line 0005a09f 00000000 00000000 17f57a11 2**0
8 .debug_macinfo 0072b58f 00000000 00000000 17fb1ab0 2**0
9 .debug_pubnames 000066c4 00000000 00000000 186dd03f 2**0
10 .debug_str 00014fe5 00000000 00000000 186e3703 2**0
11 .comment 0000142e 00000000 00000000 186f86e8 2**0
CONTENTS, READONLY
12 .debug_frame 000097e8 00000000 00000000 186f9b18 2**2
13 .debug_loc 0003ba19 00000000 00000000 18703300 2**0
14 .debug_aranges 00002360 00000000 00000000 1873ed20 2**3
15 .debug_ranges 00002c60 00000000 00000000 18741080 2**0
Note the “filesz 0x17eb0b80 memsz 0x17ebb768” (ie, 401279872 and 401323880)
With the script modified to explicitly set the start of the .data section (back to ~10MB .axf file, but still ~400MB .bin), it shows:
Program Header:
filesz 0x00047aa4 memsz 0x0005268c flags rwx
Sections:
ALLOC
3 .data 00000b74 180c000c 180c000c 00046f90 2**2
4 .bss 0000abdc 180c0b80 180c0b80 00047b04 2**2
ALLOC
5 .debug_abbrev 00018e3f 00000000 00000000 00047b04 2**0
6 .debug_info 0008dff2 00000000 00000000 00060943 2**0
7 .debug_line 0005a09f 00000000 00000000 000ee935 2**0
8 .debug_macinfo 0072b58f 00000000 00000000 001489d4 2**0
9 .debug_pubnames 000066c4 00000000 00000000 00873f63 2**0
10 .debug_str 00014fe5 00000000 00000000 0087a627 2**0
11 .comment 0000142e 00000000 00000000 0088f60c 2**0
CONTENTS, READONLY
12 .debug_frame 000097e8 00000000 00000000 00890a3c 2**2
13 .debug_loc 0003ba19 00000000 00000000 0089a224 2**0
14 .debug_aranges 00002360 00000000 00000000 008d5c40 2**3
15 .debug_ranges 00002c60 00000000 00000000 008d7fa0 2**0
Note the “filesz 0x00047aa4 memsz 0x0005268c” (ie, 293540 and 337548).
This is now about the same as the original - so why is the .bin file still bloated
Do I need to change the options to objcopy (which creates the .bin from the .axf)
If so, how
