You should use absolute path instead of ./
I used the absolute path and the process went ahead.
But the Legato has become stopped same as before.
Also the result of AT!IMAGE? is as follows.
At!IMAGE?
FW 1 FOTA 1 0 0 001.026_000 02.28.03.05_KDDI
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
Max FW images: 3
Active FW image is at slot 1
PRI FF GOOD 0 0 0 002.040_002 02.18.05.00_ATT
PRI FF GOOD 0 0 0 001.024_000 02.28.03.05_DOCOMO
PRI FF GOOD 0 0 0 002.056_000 02.25.02.01_GENERIC
PRI FF GOOD 0 0 0 001.026_000 02.28.03.05_KDDI
PRI FF GOOD 0 0 0 001.032_000 02.28.03.05_SIERRA
PRI FF GOOD 0 0 0 001.028_000 02.28.03.05_SOFTBANK
Max PRI images: 50
KDDI is not added to, but DOCOMO is replaced with KDDI.
We need to look for another approach.
Regards,
Better try with another module
We have WP7603 as well.
Do you know whether WP7603 support DOCOMO?
I should have checked the specifications first.
WP7603 does not support B1 band that DOCOMO is using.
Sorry for having disturbed you.
Regards,
I’ve tried and found that even though the active Legato frame work is for KDDI, if SIM is for DOCOMO, WP7605 would connect to DOCOMO.
Is it correct that the Legato framework itself does not affect the operation of MODEM?
We need to connect our device to DOCOMO, KDDI and SOFTBANK, but WP7605 seems to load just one Legato framework at a time.
Do you know the document that explains the difference among Legato frameworks for DOCOMO, KDDI and SOFTBANK?
Thanks in advacnce for your help.
Regards,
you can check ati8 for the legato version for comparison.
I might have misled you, sorry.
I’d like to know the differences of the functionalities among the three Legato frameworks, that are “WP76xx_Release13.3_DOCOMO.spk”, “WP76xx_Release13.3_KDDI.spk” and “WP76xx_Release13.3_SOFTBANK.spk”.
I don’t think the difference is just the name of the files.
Regards,
The carrier PRI file is different
But if you check the ati8 legato version, are they the same?
I’ve checked the build information as follows.
at!IMAGE?
FW 1 FOTA 1 0 0 001.028_000 02.28.03.05_SOFTBANK
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
Max FW images: 3
ati8
Legato Ver: 19.02.0_1c71a0d5cac35370eb79c56806e2139a
Yocto Ver: SWI9X07Y_02.28.03.05 2019-07-08_12:55:31
OS Ver: Linux version 3.18.131 (oe-user@oe-host) (gcc version 7.3.0 (GCC) ) #1 9
LK Ver: SWI9X07Y_02.28.03.05
RootFS Ver: SWI9X07Y_02.28.03.05 2019-07-08_12:55:31
UserFS Ver: unknown
MCU Ver: unknown
at!IMAGE?
FW 1 EMPTY 0 0 0
FW 2 FOTA 1 0 0 001.024_000 02.28.03.05_DOCOMO
FW 3 EMPTY 0 0 0
Max FW images: 3
Active FW image is at slot 2
ati8
UserFS Ver: unknown
MCU Ver: unknown
It seems the difference is just the file name!
So, we can use the same Legato framework for DOCOMO and SOFTBANK.
they have same legato image:
