I see that the WP7610 modem comes with three firmware images:
at!image?
FW 1 GOOD 8 0 0 ?_? 02.28.03.01_?
FW 2 GOOD 3 0 4 002.107_000 02.37.06.00_VERIZON
FW 3 GOOD 7 0 0 ?_? 02.28.03.03_?
Max FW images: 3
Active FW image is at slot 1
PRI FF GOOD 0 0 0 002.071_006 02.28.03.01_ATT
PRI FF GOOD 0 0 0 002.068_002 02.28.03.03_GENERIC
PRI FF GOOD 0 0 0 002.107_000 02.37.06.00_VERIZON
Max PRI images: 50
There is also the possibility to use SIM-based switching with the following AT command:
AT!IIMPREF=“AUTO-SIM”
Since our device will be used across the North-American continent, I would like explore the possibilities of this. Our devices do not travel the continent continuously, but usually stay in one place. So, it is possible to choose a proper firmware image once the device is there. But the installation and commissioning is often done outside the Amrican continent (Europe). And knowledge about firmware switching is practically nill throughout our company. It’s just me so to speak…
The question therefore is; what are the advantages and disadvantages of using this?
Thanks in advance.
