I have “AUTO-SIM” feature enabled on a rev C MC7455. From time to time image switch fails when sim card is swapped. Application note EM/MC74xx Auto SIM Feature
2174123-1.2 mentions that AUTO-SIM feature “needs Release 16 FW which has bugs addressed”. Which FW does it refer to?
I also tried AUTO-SIM feature on a rev B MC7455 and it does work reliably.
Below is output of at!image? when switch failed.
at!image?
FW 1 GOOD 2 0 0 ?? 02.08.02.00?
FW 2 GOOD 6 0 1 ?? 02.24.03.00?
FW 3 GOOD 1 0 0 ?? 02.14.03.02?
FW 4 GOOD 5 0 1 ?? 02.20.03.22?
Max FW images: 4
Active FW image is at slot 255
PRI FF GOOD 0 0 0 002.009_001 02.08.02.00_ATT
PRI FF GOOD 0 0 0 002.021_000 02.24.03.00_GENERIC
PRI FF GOOD 0 0 0 002.012_001 02.14.03.02_SPRINT
PRI FF GOOD 0 0 0 001.000_000 00.00.00.00_OEMPRI918
PRI FF GOOD 0 0 0 002.026_001 02.20.03.22_VERIZON
Max PRI images: 50
Output of at!image? when switch was successful.
at!image?
FW 4 GOOD 7 0 1 ?? 02.20.03.22?
Max FW images: 4
Active FW image is at slot 4
Max PRI images: 50
at!impref?
!IMPREF:
preferred fw version: 00.00.00.00
preferred carrier name: AUTO-SIM
preferred config name: AUTO-SIM_000.000_000
current fw version: 02.20.03.22
current carrier name: VERIZON
current config name: VERIZON_002.026_001
Thank you,
Dmitri K
