I am trying FW upgrade of RC7611. I would need to use AUTO-SIM as I am not sure which SIM I will use.
I used separate CWE files and NVU files, instead of SPK, as I don’t want to store all of the SPK files for each carrier (to save memory). The upgrade goes smooth, but at!impref gives ‘fw version mismatch’. at!priid lists the correct PRIs, but at!impref reads old PRI. Not sure why.
at!impref?
!IMPREF:
preferred fw version: 00.00.00.00
preferred carrier name: AUTO-SIM
preferred config name: AUTO-SIM_000.000_000
preferred subpri index: 000
current fw version: 00.08.20.00
current carrier name: GENERIC
current config name: GENERIC_001.093_000
current subpri index: 000
fw version mismatch
at!PRIID?
PRI Part Number: 9909591
Revision: 001.013
Customer: GENERIC
Carrier PRI: 9999999_9909693_SWI9X07H_00.08.20.00_00_ATT_001.074_000
Carrier PRI: 9999999_9909667_SWI9X07H_00.08.20.00_00_GENERIC_001.094_000
Carrier PRI: 9999999_9909717_SWI9X07H_00.03.03.00_00_SIERRA_000.027_000
Carrier PRI: 9999999_9909696_SWI9X07H_00.08.20.00_00_TMO_001.050_000
Carrier PRI: 9999999_9909694_SWI9X07H_00.08.20.00_00_VERIZON_001.066_000
If I explicitly set at!impref to GENERIC, reset modem and then set at!impref to AUTO-SIM, then it works ok. No more mismatches.
at!impref=“GENERIC”
at!reset
at!impref?
!IMPREF:
preferred fw version: 00.08.20.00
preferred config name: GENERIC_001.094_000
current config name: GENERIC_001.094_000
at!impref=“AUTO-SIM”
at!impref?
!IMPREF:
But can we not set at!impref to AUTO-SIM right after upgrade? I would like to avoid this additional reset step if possible.
