EM9191 Missing PRIID, IMPREF, SKU
I’m a few weeks into using this modem and just upgraded the firmware to the latest generic SWIX55C_03.09.11.00/030.044_000
The SIM is connecting but some checks show missing values, and nothing in PRI image slots:
AT!ENTERCND="A710"
AT!PRIID?
PRI Part Number: Unknown
Revision: Unknown
Customer: Unknown
Carrier PRI: None
AT!IMPREF?
!IMPREF:
 preferred image setting does not exist
 current fw version:      03.09.11.00
 current carrier name:
 current config name:
 current subpri index:    000
 fw version mismatch
 carrier name mismatch
 config name mismatch
AT!IMAGE?
TYPE SLOT STATUS LRU FAILURES UNIQUE_ID   BUILD_ID
FW   1    GOOD   127 0 0      ?_?         03.04.03.00_?
FW   2    GOOD   127 0 0      ?_?         03.09.11.00_?
FW   3    EMPTY  0   0 0
Max FW images: 3
Active FW image is at slot 255
Max PRI images: 50
AT!SKU?
!SKU: Unset
Not exactly sure what went wrong or how to populate that info.
If I try set the image like AT!IMAGE="GENERIC" it also fails, not surprisingly.
The older firmware version had the same issues…
Any help is appreciated, thanks!
@danielk43
That is very odd, its definitely not going to be able to attach to the network.
Can you use the one click updater to load the signaling firmware and PRI then post the log file?
Alternatively you could try loading multiple images onto the unit using the MBPL firmware download tool if you want to do it on Linux, I have attached an example.
EM91 update multiple images PRI + signalling using MBPL download tool.txt (17.3 KB)
Also if you want to use the teraterm script (its just a text file) to get the status of the unit (use the script or send the commands manually).
EM91 status.ttl (1.5 KB)
Hi @mlw,
Was able to complete the linux steps using the examples you provided -
fw + pri IMAGEs, IMPREF populated (no -w or -n switches previously, or have USB drivers installed while issuing fwdwl cmd)
PRIID still reported unknown w/ SIM connected, set manually (can I just set the values using filename as in the output?)
SKU Still missing…
But it seems like all the FW upgrades were successful this time:
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB0, 20:23:39
Press CTRL-A Z for help on special keys
ati3
Model: EM9191
Revision: SWIX55C_03.09.11.00 7bf975 jenkins 2022/06/10 20:36:01
IMEI: 355866235646598
IMEI SV: 22
FSN: 8W1157036304A1
+GCAP: +CGSM
at!entercnd="A710"
at!image?
FW   2    EMPTY  0   0 0
FW   3    EMPTY  0   0 0
Max FW images: 3
Max PRI images: 50
# exit minicom
$ sudo ./fwdwl-litehostx86_64 -p /dev/cdc-wdm2 -t 1 -f ./em9/SWIX55C_03.09.06.00-001_TMO_030.035_000 -w SWIX55C_03.09.06.00-001.cwe -n SWIX55C_03.09.06.00-001_TMO_030.035_000.nvu
Application version: 1.0.2204.2
INFO: QDL Port  :
INFO: Device Path: /dev/cdc-wdm2
INFO: FW  Path  :  ./em9/SWIX55C_03.09.06.00-001_TMO_030.035_000
Target image Info:
Carrier    :TMO
FW Version :03.09.06.00
Model ID   :SWIX55C
Package ID :000
PRI Version:030.035
SKU        :9999999
Switching device into download mode ...
Modem Needs FW
Modem Needs PRI
Waiting for modem to disconnect from the host ...
Modem disconnected from host.
Waiting for modem to come up in BOOT and HOLD mode ...
QDL port found: /dev/ttyUSB0
BOOT and HOLD Mode. Downloading firmware ...
Downloading: ./em9/SWIX55C_03.09.06.00-001_TMO_030.035_000/SWIX55C_03.09.06.00-001.cwe
Downloading: ./em9/SWIX55C_03.09.06.00-001_TMO_030.035_000/SWIX55C_03.09.06.00-001_TMO_030.035_000.nvu
FW download succeeded.
Waiting for modem to come up in ONLINE mode ...
Modem is now in ONLINE mode ...
FW update status: Successful
FW info from modem:
Model ID            : EM9191
FW Version          : SWIX55C_03.09.06.00
Carrier Name        : TMO
Carrier PRI Revision: 030.035_000
Firmware Download Process completed
Exiting Application!!!
$ sudo ./fwdwl-litehostx86_64 -p /dev/cdc-wdm2 -t 1 -f ./em9/SWIX55C_03.09.11.00-001_GENERIC_030.044_000 -w SWIX55C_03.09.11.00-001.cwe -n SWIX55C_03.09.11.00-001_GENERIC_030.044_000.nvu
INFO: QDL Port  :
INFO: FW  Path  :  ./em9/SWIX55C_03.09.11.00-001_GENERIC_030.044_000
Target image Info:
Carrier    :GENERIC
FW Version :03.09.11.00
Model ID   :SWIX55C
Package ID :000
PRI Version:030.044
SKU        :9999999
Modem Needs FW
Modem Needs PRI
Downloading: ./em9/SWIX55C_03.09.11.00-001_GENERIC_030.044_000/SWIX55C_03.09.11.00-001.cwe
Downloading: ./em9/SWIX55C_03.09.11.00-001_GENERIC_030.044_000/SWIX55C_03.09.11.00-001_GENERIC_030.044_000.nvu
FW info from modem:
Model ID            : EM9191
FW Version          : SWIX55C_03.09.11.00
Carrier Name        : GENERIC
Carrier PRI Revision: 030.044_000
OPTIONS: I18n
Port /dev/ttyUSB0, 20:35:09
at!entercnd="A710"
at!impref?
!IMPREF:
 preferred fw version:    03.09.11.00
 preferred carrier name:  GENERIC
 preferred config name:   GENERIC_030.044_000
 preferred subpri index:  000
 current carrier name:    GENERIC
 current config name:     GENERIC_030.044_000
at!image?
FW   2    GOOD   128 0 0      ?_?         03.09.06.00_?
FW   3    GOOD   129 0 0      ?_?         03.09.11.00_?
Max FW images: 3
Active FW image is at slot 3
PRI  FF   GOOD   0   0 0      030.044_000 03.09.11.00_GENERIC
PRI  FF   GOOD   0   0 0      030.035_000 03.09.06.00_TMO
Max PRI images: 50
# installed em9191 back in router
# ROOter at-cmd terminal:
at!entercnd="A710"
at!priid?
Revision: Unknown
Customer: Unknown
Carrier PRI: 9999999_9909621_SWIX55C_03.09.11.00_01_GENERIC_030.044_000
Carrier PRI: 9999999_9910308_SWIX55C_03.09.06.00_01_TMO_030.035_000
at!priid="9909621","030.044","GENERIC"
at!sku?
!SKU: Unset
Thanks for all your help.
Rgds,
Daniel
I will add here for other bone heads like me.
Make sure you stop the ModemManager process on your Linux computer. I ran an update on one modem. Walked away. Came back. Had to reboot the computer for an unrelated reason. Went back to updating a modem and kept getting FIREHOSE errors. Spent WAY longer than needed to figure out it was the ModemManager process jacking it up.
Also, @ danielk43
Do you happen to know the EXACT proper syntax for the fdt2.exe tool on Windows10 to add an updated fw image and the associated PRI images, WITHOUT overwriting the last fw image in slot 1 and subsequently orphaning the PRI associated with that last fw image?
I keep running the fdt2.exe tool and successfully flashing firmware images to the EM9191, but they keep writing themselves in the fw slot # 1, instead of in slots 2 or 3. I can’t figure out why. Works fine when I do as you posted an example of in Linux using fwdwl-lite. Not when using fdt2.exe in Windows10. I really need the Win10 way to work properly.
Here is an example of the commands I run, again in Windows 10 “command line” ran inside the folder with the images:
fdt2.exe -d g5k -ignswto -prto 120 -resettimeout 3 -timeout 15 -f S03.09.06.cwe S03.09.03.cwe GEN.nvu VZW.nvu ATT.nvu TMO.nvu -mi -impref S03.09.06.cwe GEN.nvu -force -log logs
Before anyone says anything: I use -force to make sure it runs the whole flash process while I’m troubleshooting, regardless of whether the image I’m flashing is there already or not. I’ve run it without and it does the same thing. Not related to the issue as far as I can tell.
