after playing arround serveral hours I tried to update my EM7455 to the latest firmware but there will be no Carrier PRI installed, so i got a carrier/config name missmatch error.
My COM ports are working and i can connect via Terminal to the card. I also can flash the card, but the PRI will not be activated on the card.
first I tried to flash this firmware.
9999999_9904609_SWI9X30C_02.32.11.00_00_GENERIC_002.064_000.exe
now i also tried to flash this firmware:
9999999_9904609_SWI9X30C_02.30.03.00_00_GENERIC_002.046_001.exe
but still the same problem…
WHAT I DID?
i connect via terminal and delete all images on the card
AT!ENTERCND="A710" AT!IMAGE=0 AT!RESET
Flashing the firmware via .exe on Windows 10.
after that i reconnect via terminal and did this:
AT!ENTERCND="A710" AT!PRIID="9904609","002.046","GENERIC" AT!RESET
after that i check the terminal and got this back:
AT!PRIID? PRI Part Number: 9904609 Revision: 002.046 Customer: GENERIC Carrier PRI: None !IMPREF: preferred fw version: 02.30.03.00 preferred carrier name: GENERIC preferred config name: GENERIC_002.046_001 current fw version: 02.30.03.00 current carrier name: current config name: carrier name mismatch config name mismatch AT!IMAGE? TYPE SLOT STATUS LRU FAILURES UNIQUE_ID BUILD_ID FW 1 GOOD 1 0 0 ?_? 02.30.03.00_? FW 2 EMPTY 0 0 0 FW 3 EMPTY 0 0 0 FW 4 EMPTY 0 0 0 Max FW images: 4 Active FW image is at slot 1 TYPE SLOT STATUS LRU FAILURES UNIQUE_ID BUILD_ID PRI FF GOOD 0 0 0 002.046_001 02.30.03.00_GENERIC Max PRI images: 50 ATI Manufacturer: Sierra Wireless, Incorporated Model: EM7455B Revision: SWI9X30C_02.30.03.00 r7804 CARMD-EV-FRMWR2 2018/07/25 01:10:04 IMEI: 359073060005307 IMEI SV: 17 FSN: LF511200380302 +GCAP: +CGSM AT!USBPID? !USBPID: APP : 9071 BOOT: 9070 AT!USBVID? !USBVID: 1199
Any other idea how to get this GENERIC PRI to work?
Maybe i forgot something?
