How can I create the .dwl files to download to the module?
Hello all!
How can I create the .dwl files to download them to the module? I use the Q2406A module.
Thanks.
You must compile your code in Wismo Target Mode instead of debug.
Your compiler will create a dwl file in your_project/your_compiler/out
gdt
Thank you very much gdt.
Best regards
Mine is set up like this, with the Wismo Target as my active configuration. I stll don’t get .dwl files though?
I’m trying the Ping_GPRS example, and it compiles to files called gcc_Ping_GPRS_B.* with the *'s being:
.dep
.flt
.src
I have an gen.backtraces64k.axf file, as well as an opec_asm.o file.
When I do my build, I get this error:
Check environment settings…
Launch a full library or binary process
…/out/gcc_Ping_GPRS_B.flt:34: *** target pattern contains no `%’. Stop.
Find errors occurred when using SGT
Anyone have any ideas why this would be happening? Any help/direction would be greatly appreciated.
I found out it didn’t like the normal install of Cygwin. I re-installed evreything, and for the Cygwin part, I used their Cygwin files on the CD. It seems the newer versions of Cygwin don’t work very well.
I had this problem as well. Replace make with version 3.80. 3.81 removed support for windows filenames for some reason.
Cheers!
Mark
