i written one application for Q2406B and now wanted to run in module in ruy time.
uptil now i was running in Target monitoring tool i.e. in debug mode.
and now i need to download in module and want to run.
so needs some help.
in my project folder-> GCC->
there are two .dwl file are generated 1) myapp.wpb.dwl 2) myapp.dwl
which one file is to be download.
and other q is can i use XMODEM (through Hyper Terminal) to download.
one more q is that
after downloading my application sucessfully i need to use AT+WOPEN=1 ok
q is if module is restarted, automatically application starts running or i need to give again AT+WOPEN=1 command
I think you must download firmware to fix this problem. You can get it from Distributor and download with DWLwin program. Next time, you should download appl by hyperterminal, it is faster.
ttt
