I have bunch of GX400 (ROW HSPA+ models) which have quite old firmwares.
I decided to get them up-to-date and ran into problems with first two.
First had 4.2.1 and other 4.3.0
To get to 4.4.0 I should go trough upgrade path 4.3.2 -> 4.3.2a -> 4.3.3 -> 4.3.4 -> 4.4.0
In some stage I should be prompted to Radio firmware upgrade also.
I installed the 4.3.2.009 from ROW HSPA+ updatepack ( Filename says “InstallMeFirst…”)
After upgrade I proceeded to 4.3.2a.010 “InstallMeSecond”
MC8705_OSM001_T1043D.bin is required in order to continue the upgrade process.
Try performing a restore defaults on your modem before continuing, to ensure there are no settings in place.
Also try performing the updates including the radio module T1043D update through various web browsers, Firefox, IE 11( and try in compatibility mode IE 8/9 )
If the issue continues, you may want to contact your reseller.
I have identical problem. Radio Firmware Version is T1_0_3_2AP R361 CNSZXD00000061 2011/04/15 17:40:48
and should be compatible for ALEOS_Software_4.3.2a.010_InstallMeSecond.
If trying, wrong rm version is informed.
If trying to program MC8705_OSM001_T1043D, bad image is given.
So I’m stuck to have ALEOS_Software_4.3.2.009_InstallMeFirst version.
Why this is so hard?
Do I need to drop Sierra totally or is there a way to make it safe and have a latest fw’s installed ?
Any help?
