I recently decided to upgrade my GX400 firmware from 4.3.3 to 4.3.4, as the first step to upgrade to the latest firmware. Figuring that it would take a while, I started the process then left it alone for several hours. Upon returning, I restarted the GX400 and logged in to the Acemanager interface which showed the firmware version to be 4.3.4, this being done within (say) 20 seconds of rebooting the device. I then lost the connection, and had no success in reconnecting until I rebooted the GX400. Again, after 20 seconds or so I lost the connection. I did a port scan on the default (192.168.13.31) address, and ports 22 and 9191 are open, so it would seem that something may have gone astray during the firmware update. As I do not really want to use the GX400 as a door stop, is there a painless way to resolve this, or do I need to return the unit to Sierra Wireless ?
Did you try to download the same Firmware once more??
-Alex
No, once was enough !! After the seemingly failed update attempt, the web interface no longer stays up long enough to allow access to the firmware update page, so I could not do that even if I wanted to…
Mike
