I have a GX400 that constantly loses connection to the RF channel. It cycles through every 30 seconds or so and reports that “data connection failed…” and then “connecting to network…”. The funny thing is that I can finally get it to stabilize after several factory defaults… Also, this only happens when something is plugged into the ETH port of the EVDO???
The version of software and firmware are both set to the latest and greatest. The configuration on the EVDO is very minimal; GRE tunnel, SNMP, DHCP server on ETH interface, and that’s it from the defaults.
My carrier is VzW. I have not reached out to carrier as of yet because the EVDO is fine when nothing is connected and eventually stabilizes after several reboots.
Any ideas or thoughts would be extremely welcome!
Thank you!
