GPRS configure fields in cfg_gprs.c
Hello
My programmer is confused of what are the fields defined in cfg_gprs.c should be:
#define GPRS_APN      "websfr"
#define GPRS_USER     "a2b"
#define GPRS_PASSWORD  "access"
#define GPRS_PINCODE  "0000"
if my sim card does not require “user id”, “password” and don’t have pincode
Should it be like:
 #define GPRS_APN      "embeddedworks.globalm2m.net"
#define GPRS_USER     ""
#define GPRS_PASSWORD  ""
#define GPRS_PINCODE  ""
Note that the “user id” and “password” here have nothing to do with the SIM - they are for the APN connection.
Yes, that should be OK - but see viewtopic.php?f=28&t=3496&p=13269&hilit=password+single+space#p13269
BTW: “embeddedworks.globalm2m.net” looks like Jasper - is it?
  1. miken said: Using ’ ’ for username and passwored worked! THANK YOU!
    But did he mean " " or ’ ’ ?
2)Yes it is jasperwireless.com
Question here : module Q24Plus is certified for use outside of the United States on jasper platform
jasperwireless.com/platform/ … vices.html
Is it only with jasper?
What if i will try to use it in US ?
How they will know that i use Q24Plus(i have their sim with data plan )
If the null string works for you, then you have no worries - the single space is just an option to try if the null string doesn’t work (it’s a string containing a single space).
IIRC, the null string should work with Jasper.
Their support is pretty good; make the most if it - talk to them!
Speak to your Distributor about that.
Speak to Jasper about that!
