Gmm-g3 compatibility
AirPrime has SDK command.
SDK commands are only supported on flash-based GNSS modules.
Gmm-g3 are flash-based GNSS modules?
Gmm-g3 have “3D_FIX” pin. @pin_number13
How to work “3D_FIX” pin at firmware ver 5.11?
@atec,
Can you confirm what you mean by an SDK?
I do not want to use “PGCMD”.
But I can not set GPS only.
I send $PMTK353,1,0,0,0,02A, gps module go reboot.
I send $PMTK353,1,1,0,0,0
2B, not reboot.
so PMTK353 is Unavailable.(5.1.1 Customer Release Note)
What should I do?
Is there a way to not use “PGCMD”?
(AXN5.1.1_8525_3333_1152.1151100.1)
@atec,
So do you mean is there a way to set the unit to only use GPS without sending it an commands? No there isn’t, the unit comes configured as is and you,as a system integrator, need to configure it as per your system requirements.
