Hello, I couldn’t find a similar topic to that one.
I have made the setup exatly like in manual:
- SIM card is insterted correctly.
- Given power is between 6-24V a max current is set to 1A
- Modem is connected to laptop device through SERIAL-USB cable
- Device (or let say the connector) is detected by one of the ports.
- I am not able to send commands to that device using PuTTY software.
After that LED lights continuously, which means it didn’t register.
I have made second setup (I didn’t see an example of that in manual). I used the microUSB Port instead of SERIAL and only thing thath changed is that the device is not detected by Windows, on any port.
I eliminated the problem with SIM card, because it works with different model (I don’t remember which model, but i can say that is USB powered only).
I appreciate any help with that.
