Hello, I’m new using these devices and I’m looking to do what I thought would be a simple embedded modem to connect to the internet.
I’m using this device to replace an older USB cell modem from AT&T, which was connected into the usb on a wireless router. Most carrier usb modems don’t offer external antenna setups, which is why I picked this up.
Currently I’m just connecting the GL7500 to my laptop for initial testing. I have a data only sim card from Verizon, which has been tested in other modems and works just fine.
Thus far I have done:
- Downloaded and installed USB drivers
- supplied the device with 6v power
- Connected usb cable from Laptop to device
*LED light is blinking at the slow flash rate
- indicates that its registered in the network. - Connected to device via Putty
- AT commands work just fine.
- AT
>OK
- AT+CPIN?
> +CPIN: READY
- AT+CSQ
> +CSQ: 15, 5 Received signal strength appears to be good
- AT+CREG?
> +CREG: 0, 3 This doesn’t appear to be a response in the manual.
so I downloaded airprime HL7588 AT Commands Interface Guide
Found that 0, 3 indicates Registration denied.
Any insight as to what steps I should take next to resolve this? Is it possible that Verizon has blocked my device itself? which is why registration has been denied?
