since there are SIM cards with fixed IP addresses i believe it should be possible to create a proxy program, running on the GL6110, which can be accessed through a telnet session and which forwards the received input to the target device attached via USB and returns the response from the target device to the telnet client.
ie:
client opens a telnet session and sends an ascii command
proxy forwards this to the target device which is connected via USB
proxy reads answer from target device and sends it back to telnet client
i had a look at the tcp_server sample application because i plan to start with it and then extend it with the USB sending/receiving part.
does all this make sense to you? is it doable at all? i’m completely new to embedded software development and m2m topics in general but i was asked to find a solution for this scenario.
Are you sure that the SIM IP address is also routable? i.e. Most ISPs provide you with an IP address in the non-routable range (10.x.x.x, 192.168.x.x). This IP address may be fixed, but will not be accessible from the internet in general.
I have done something similar to this on the old Fastrack Supreme using CSD - it proxied a dial-up connection to different serial ports.
Also depends on what’s on the other end of your USB link.
i was told that there are SIM cards with fixed IPs although i haven’t actually worked with one yet. i need to find out if they are routable… thanks for pointing this out!
