I am using a GL6110 USB modem which is connected to an embedded device. The modem is set to continuous mode. I created a TCP server in the embedded device side(through GPRS network with this GL6110), then I use a PC tool to connect to this TCP server, and exchange data. It worked but we met the problem :
Some times the data the embedded device sent to USB modem is not received in the peer side(PC). And it happens quite often.
1.Any possible solution/workaround to fix it?
2.Is continuous transparent mode better?
3.Any WIP parameters I need to adjust or check to avoid this issue?
Thanks!
BR,
