USB Power issues with GL6110
Hi, I noticed a power supply issue with GL6110. It seems to draw a lot of power, sometimes, if there is another USB device attached to the PC, the modem will not work properly.
The specs says: SUPPLY VOLTAGE 4,75V to 32V DC input, [2A peak/4,75V, 3mA Idle]
2A is a lot of USB power! If i need to connect 16 modems, what is the power requirement for the USB hub i need? Thanks. :smiley:
what do you mean when you say “the modem will not work properly”.Do you see some errors :question:
what is your specific requirement ??
Thanks for replying, I found the solution, just use an externally powered USB hub.
By the way, if you know, please help with https://forum.sierrawireless.com/t/error-when-installing-gl6110-usb-driver/5169/1
