I am new to wavecom products. I recently just bought a FASTRACK supreme 20 + IESM IO+USB. My main objective is to capture data from sensor (e.g temperature and light intesity sensor) and use the GPRS connection established by the modem to send the data to a database.
Currently, I managed to established the GPRS connection without any problem. But so far I cannot seem to figure out how to capture the data from the sensor. I was thinking of using the IO port for the IESM IO+USB. Is this solution possbile or is there any other feasible solution.
The main program I am using to create this project is Visual Basic 6.0
That would depend entirely on what sensor you’re using, and what interface it provides!
It would have been sensible to have discussed this with your Wavecom Distributor before you committed to buying the Fastrack!
The specifications of the IESM’s IO ports are given in the IESM [b]Product Technical Specification /b - you need to review those specs and see if they can meet the requirements of your sensor(s).
In that case, you will be communicating with & controlling the Fastrack using AT commands - so you will need to study the AT Commands Manual (“AT Commands Interface Guide”)
