Hi.
I’m connected to FXT009 via RS232. I can send AT commands but when I run Developer Studio get errors:
Imposible to detect binaries,
Embedded module: Imposible to detect wcpu type
Version: version of firmware Binary detection failed
Version: version of firmware bootloader detection failed
FXT009 ver.
AT+CGMR
R7.46.0.201108091301.FXT009 2216044 080911 13:01
OS: WIN7 x64,
RS232 - USB to RS232 bridge ATEN UC232A WIN7 64bit
In attachment i send file with error details.
Can anyone help me to solve the problem??
Best regards
SS.
fxt009 error.txt (13 KB)
I suspect that you use Dev Studio v3.x. It does not support modules running 7.4x FW. You need to install dev studio v2.3.2:
http://developer.sierrawireless.com/Resources/Resources/AirPrime/Software/Open%20AT%20Application%20Framework.aspx
Hi.
Thanks for answer.
It helps for a while, after installation this software i update bootloader via Open AT and firmware to 7.51 via hyperterminal.
at+cgmr
R7.51.0.201306260837.FXT009 1713240 062613 08:37
Then i try to update firmware 7.52 but upload stops in a half.
In Open AT soft get errors again.
Now, when i send at+wopen or ATI<> command i get error.
Re-uploading 7.51 firmware does not help.
I have 2 fxt009 modems and both have this issue.
Any solution?
Best regards.
SS
kuoni
September 12, 2014, 1:04pm
#4
Try looking at my post a few months ago, you may be having the same issue. Uploads would always stop until I did some strange things.
https://forum.sierrawireless.com/t/fxt009-via-usb-every-command-returns-error/7182/1
Hi kuoni
it really is very strange, but works… thaks a lot ))
