Led not blinking means you are not registered on the network, probably because PIN is needed.
To connect over Hyperterminal you should configure it as 115200 bauds, 8 bits, 1 stop, no parity, and Hardware flow control.
Good luck
Thank you for the response. The SIM card has been in use for over 2 years and if inserted in a phone and can make and receive calls and SMS. Is there any other registration I need to do with the PTO? I have configured with all the details below but still cant run AT command on the modem using hyperterminal.
thanks for your assistance so far. I visited the link but the link on the page to DWLwin is broken. Also let me know how to upgrade the firmware
after downloading the application.
Sorry,
I’m not sure I have understand you. You are using the Fastrack as an AT commanded modem. Is that rigth? In that case there’s no application to download.
With the DWLwin you are going to reload (not necessarily upgrade) the firmware. Ask your distributor for it actually I cann’t find were is it stored in Wavecom’s web…
Yes I did. I got it from a supplier in Ireland gprsmodems.co.uk. i was given the configuration details and was also asked to check the wavecom site
for installation documents. the details did not work and the manuals on wavecom.com were not helpful.
I tried contacting wavecom to order directly from them based on the infomation I got from their stand during the GSMA conference in Barcelona
but no luck. I am currently looking at ordering from another source but am really sceptical about this.
