FASTRACK M1306B - comunication problems
Hi there
I’ve this model: FASTRACK M1306B connected to a server with a standard cable provided with the modem
reading another posts i disable pin 3 (boot) and 13 (ring indicator) by removing the pin.
But using hyperterminal no response from device and red light continuosly blinking red on device.
How i can connect properly this device?
I must have the device recognized under server?
any suggestion?
thanx a lot
Surely, the standard cable provided with the modems is specifically designed to connect the modem’s 15-pin connector to a PC’s 9-pin connector?! :confused:
You should not be modifying it in any way! :open_mouth:
What posts(s)?
Provide the link(s)!
Which connector are you referring to - the 15-way, or the 9-way?
Why are you removing pins??!! :open_mouth: :open_mouth:
Hi
i removed pin 15 and 3 by cut them in 15 pin connector!
here where i read removing pin:
wavecom.com/modules/movie/sc … php?t=1120
Now, if the pin 3 and 15 is removed…the device is fully funcional?
I think i’m very stupid man!!!
are you saying you read your own post?
sorry, i’ve linked my post!!!
here where i read:
wavecom.com/modules/movie/sc … php?t=1014
sorry…
