alenico
1
I have made by myself the cable to adapt the 15pin connector(FASTRACK) to 9pin connector(PC).
In some modems, the connection is working, in others it isn’t.
I have used RX, TX, RTS, CTS and GND pins.
Do you have any suggestions?
Is it possible to have the complete description how the cable should be done? (connections???)
Thanks a lot for your help.
I think this will be helpful to you.
SUB-D 9CTS SUB D 15CTS (RS232) Signal name
1 (White) 1 (White) DCD (CT109)
2 (Grey) 6 (Grey) RX (CT104)
3 (Violet) 2 (Violet) TX (CT103)
4 (Blue) 8 (Blue) DTR (CT108/2)
5 (Black) 9 (Black) GND
6 (Orange) 7 (Orange) DSR (CT107)
7 (Yellow) 12 (Yellow) RTS (CT105)
8 (Brown) 11 (Brown) CTS (CT106)
9 (Green) 13 (Green) RI (CT125)
Modular Jack 4P/4C SUB D 15CTS (AUDIO)
1 (Yellow/White) ! 4 (Yellow/White) microphone(+)
2 (Red/White) ! 10 (Red/ White) speaker(+)
3 (Green/White) ! 15 (Green/White) speaker(-)
4 (Black/White) 5 (Black/White) microphone(-)
Flying wires SUB D 15CTS (Boot/Reset/GND)
(Pink) 3 (Pink) BOOT
(Blue/White) 14 (Blue/White) RESET
With Regards,
Sunil Rao
Helo,
I can not comunicate with the M1306, my cable is the next:
PC MODEM
6-1 (White) 8
2 (Grey) 2
3 (Violet) 6
4 (Blue) 7
5 (Black) 9
7 (Yellow) 11
8 (Brown) 12
Windows vista 64bits
I don´t know the error.
I need help.
alenico
4
Thank you SunilRao
your cable configuration is OK. It is working.
It is working on Fastrack M1306B and Supreme.
A question:
You say “…Flying wires SUB D 15CTS (Boot/Reset/GND)…”
Why GND??? I connected GND between the two connectors.
Again thanks a lot.
For IGNATIO72:
Your configuration seems not correct.
awneil
5
To assert Boot and Reset, you connect them to GND. 8)
awneil
6
Note use of the ‘Code’ tags to preserve the layout…
The pinout of the 15-Way connector is defined by Wavecom;
The pinout of the 9-Way connector is a well-defined standard;
But I’m not sure that there is any established standard for the modular jack in this type of application
