When you power the unit up (with SIM inserted & antenna connected), the red LED should come on steady;
Then, after a few seconds, it should start blinking.
Does this happen if you just power-up the unit and don’t connect it to the PC?
I got same problem. I plug the device into the power and wait for a while but the led still continuously be red (not blinking). Then i plug it to my computer and the led turn off right away.
The first time I experienced that problem was due to a wrong cable.
I was experiencing the same problem today with a proper cable.
The problem vanished when I disconnected the ring indicator wire (pin 13 of the DB15 connector).
I also suspect that Windows hyperterminal has something to do with it, but have no definitive proof yet.
Remember that the 15-pin connector includes a BOOT pin and a RESET pin - if you wire them incorrectly, you most certainly will make the modem go crazy…!!
Thanks! With the proper cable, the modem and the computer can now talk to each other. The AT command works; however, I am not able to initiate a call or send an SMS.
Here are some experienced behaviors:
A) AT+CSQ -> Answer: +CSQ: 15,0
B) The red LED is consistently on (no flashing)
C) All of the AT+COPS commands return “ERROR”
D) After AT+CPIN=xxxx, AT+CPIN? returns +CPIN: READY. After a few seconds, I get a +WIND: 3 and a +WIND: 1. Afterwards, AT+CPIN? returns +CPIN: SIM PIN… like if the PIN had to be sent again.
My configuration:
Wavecom Fastrack M1213A (900 / 1900 MHz)
Cingular SIM Card
