I have a M1306B, on power-up it has a solid red light with no changes. When I connect to it via serial (Windows 2000/Hyper-terminal) it gives no response. When I change the SIM card I get no changes in the led status light.
The power adapter was purchased from a distributor along with the serial cable as official fastrack parts.
Has anyone any ideas on why I am not seeing activity on the LED or why I am not getting any response via serial? Thanks.
It is working perfectly fine for me at 115200 bps. there seems to be no reason why it should not work with 115200 bps. what is the procedure you adopted to use 115200?? Do you use TMT or Hyperterminal ??
No my modem working fine with that baud rate(115200 bps), sometimes that red light indicator will stop blinking and also the Hyper terminal will also stop responding.
If the red light stops blinking, the modem has lost GSM registration - you should be able to see this by enabling +CREG and/or +WIND unsolicited notifications.
But losing GSM registration should not stop it communicating via its serial port.
If the red light stops blinking, and the modem stops communicating via its serial port, then the modem has crashed.
Do you have an Open-AT application running in your M1306B?
This behavior also happens in my case.
I have an Open-AT application running on M1306B.
In detail, if the modem does not have gprs coverage for a time of several days, it crashes and is necessary restore the power in order to restart the application.
Could someone give me a clue about this problem?
Thank a lot
