I’ve just found out that the legato module I have DOES NOT have a fixed MAC address associated with it. Every time it boots, another (apparently random) MAC address is generated - which requests another Ethernet Address from my DHCP server.
So each time I turn power cycle (or soft reset) the Hardware, I have to first log in with the serial console to discover the IP address before I can connect via SSH.
This is a pain … and possibly going to confuse people.
The Microchip/SMSC LAN9730 can talk to a eeprom containing the default MAC address - if this is not found it appears that the driver has to generate a valid MAC. It looks like the PCB hasn’t included this eeprom, so the Yocto driver is just inventing a ‘random’ MAC each time it starts.
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
usb0 Link encap:Ethernet HWaddr A6:1B:60:45:C5:0B
inet addr:192.168.1.2 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
[/code]
copy down the HWaddr value for eth0 (in this case it is 26:16:4F:87:BA:6E)
change directory to /etc/network
edit the file interfaces using vi
scroll down to the entry for iface eth0 and add the line
hwaddress ether 26:16:4F:87:BA:6E
where the MAC address on the line is that noted in step 3 above. Note that the line starts with a TAB character. The section of the file should look like the following:
# Wired or wireless interfaces
auto eth0
iface eth0 inet dhcp
iface eth1 inet dhcp
Save the file and exit from vi
Reboot the Legato and check both the IP and MAC address using ifconfig - they should be the same as that you’ve just entered.
Now my DHCP server is going to issue the same IP address each time…
Please note that from DS 3.1 + Legato 14.07 (https://forum.sierrawireless.com/t/developer-studio-3-1-released/11948/1), device discovery is enabled.
When configuring a new connection (or editing an existing one), it is possible to browse the alive devices on the network, that are publishing their IP address using the TCF protocol.
But … as the MAC address changes each reboot, the Legato will request a new IP address from the local DHCP server each reboot. After 256 reboots (Ok, could take some time, but not out of the realms of possibility) there is still the risk of exhausting (or reserving) all IP addresses in the DHCP server depending on how long the IP lease time is set to on the DHCP server.
At least it is probably a good idea to fix the hardware ethernet address as I’ve described before so that the DHCP server is not exhausted.
