Hi team,
I would like to set a static MAC address to the ecm (ethernet over USB) because it always changes after a reboot. I know, setNet can do that but only with eth0 and not with the usb0.
Anybody know what can be done?
Thanks!
Daniel
Hi team,
Thanks!
Daniel
Hi Daniel,
You can modify the file /etc/legato/usbsetup with the following to setup a static MAC address for ecm.
elif [ $usb_mode = "ecm" ]
then
func="${func}ecm"
echo "addr" > /sys/module/g_android/parameters/dev_addr <---- ADD THIS LINE OF CODE
where “addr” is your mac address.
After you reboot, your ecm should have a static MAC address.
NOTE: This is only a workaround at the moment. In the next release, ecm will be configured with a static MAC address by default.
Hope this helps,
Enoch
Hi esun,
Thank you for your help.
I’ve try to do your modifications in the usbsetup but the MAC address continue being different each boot. This is how the /etc/legato/usbsetup file looks like:
then
func="${func}ecm"
echo "06:99:7D:C2:73:C6" > /sys/module/g_android/parameters/dev_addr
elif [ $usb_mode = "diag" ]
then
func="${func}diag"
echo "diag" > /sys/class/android_usb/android0/f_diag/clients
else
func="${func}${usb_mode}"
fi
done
However, the dev_addr variable has changed (with the right MAC address):
cat /sys/module/g_android/parameters/dev_addr
06:99:7D:C2:73:C6
Note: Before doing this, dev_addr output was: i[/i]
What I’m doing wrong? Is there something missing?
Thanks again
Daniel
Have you upgraded to 15.01?
Sorry for the delay,
It works! I had the 15.01 version installed and checking the file and also the usb0 configuration, it prints the right MAC every boot.
Thank you!
Daniel
PS: I was checking wrong the MAC of the usb0 device :S
I have been trying to figure out how to set a static MAC address for the USB ECM. I’m currently using 18.01. Has this changed at all?
