We are currently evaluating the RC7630 module for an IoT product and would like to clarify the supported options regarding eSIM (eUICC) usage and profile provisioning.
Specifically, we would like to understand the following points:
eUICC Compatibility
Is it possible to use an independently purchased eSIM (eUICC) with the RC7630, or
Does the RC7630 require an eSIM provided or approved by Semtech/Sierra Wireless?
Profile Provisioning Method
If a third-party eUICC is supported, can profiles be downloaded via GSMA IoT RSP (SGP.02) using an SM-DP+ server?
Are there any restrictions on SM-DP+ providers or eUICC vendors that can be used?
LPA Support
Does the RC7630 firmware include a Local Profile Assistant (LPA) for eSIM profile download and management?
If so, is the LPA enabled by default, or does it require a specific SKU, firmware option, or license?
Download vs. Activation Control
Is it possible to download a profile without immediately enabling or activating it (i.e., download-only, activate later)?
What event typically triggers billing/activation (profile download, enable, or first network attach)?
Recommended Approach
For production deployments, do you recommend:
using a Semtech-provided eSIM,
selecting from a list of approved eUICC vendors, or
another provisioning approach?
Our intent is to determine whether we can source eSIMs independently, or if we should rely on vendor-supplied or vendor-approved eSIM solutions to ensure full compatibility and GSMA compliance.
