Error in log file after opning "Audio" config tab
The error is given below. Cant see any thing in “Speaker Selection” dropdown. The voice is not working. Any suggesions?
!SESSION 2009-12-29 22:27:24.143 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_17
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86 -data @user.home/expresso/workspace
!ENTRY org.eclipse.ui 4 0 2009-12-29 22:28:49.564
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.ArrayIndexOutOfBoundsException: 11)
at org.eclipse.swt.SWT.error(SWT.java:3884)
at org.eclipse.swt.SWT.error(SWT.java:3799)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at com.wavecom.configtools.commons.ui.dialogs.CDialog.open(CDialog.java:237)
at com.wavecom.configtools.com.ui.dialogs.ConsoleDialog.open(ConsoleDialog.java:132)
at com.wavecom.configtools.com.ui.handlers.ShowConsoleViewHandler.execute(ShowConsoleViewHandler.java:46)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:294)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:178)
at com.wavecom.configtools.internal.ui.ConsoleOpener$1.mouseUp(ConsoleOpener.java:62)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:207)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.wavecom.configtools.internal.application.Application.start(Application.java:35)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 11
at com.wavecom.configtools.factory.threegpp.internal.services.ThreeGPPService$30.parseResponse(ThreeGPPService.java:1091)
at com.wavecom.configtools.commons.ui.GenericUICallback$2.run(GenericUICallback.java:59)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
… 36 more
